Fake ''air'' intakes
Old Nov 13, 2018 | 04:21 PM
vika01's Avatar
Default Fake ''air'' intakes
Hello
I have really never seen a post or any journalist say this about the SVR but why would it have two big fake air intakes in the front? This is something you see from Honda and Toyota and shouldn't be on a Jaguar. Only Effspot has discussed this as far as I'm concerned.
That alone is a big reason I have never been interested in the SVR.
I love the F-type and this post is not here to upset anyone.
See 9:07 in the video.
Old Nov 13, 2018 | 04:46 PM
mlebofsky's Avatar
I have recently been wondering about those myself .... And if it would be a good idea to remove the black "air blocking" panels.
There has to be a reason the inlets are blocked off ....
Old Nov 13, 2018 | 05:01 PM
vika01's Avatar
I don't see how it's any different to what you see on the Honda Civic.
Old Nov 13, 2018 | 06:09 PM
caviarjag's Avatar
The reason is aero efficiency. Opening those inlets up would increase drag. No reason too unless there is something behind there that needs cooling. Most cars, including sports cars, have a lot of these “inlets” blocked off.
Old Nov 13, 2018 | 06:10 PM
vika01's Avatar
sounds interesting.
Old Nov 13, 2018 | 08:15 PM
Ron Gillespie's Avatar
The average motorist wouldn’t appreciate that they are ‘fake’....they would just look and go ‘wow’...
to me, the design is the design. The fake intakes simply give it a ‘look’. To me, it looks great! Never paid attention if they were real or not.
Old Nov 13, 2018 | 08:46 PM
mlebofsky's Avatar
A vertical wall of plastic seems like it would create more drag and be more detrimental than the honeycomb that gives the air a chance to flow past the hot cats.
Perhaps opening up those 2 areas creates an under the car air turbulence problem … hence they are blocked off.
Old Nov 13, 2018 | 09:45 PM
Stohlen's Avatar
Allowing the air to flow into the engine compartment will cause lift. A vertical wall at times can be more aerodynamic, depending on what your goals are for the vehicle.
Old Nov 14, 2018 | 04:51 AM
vika01's Avatar
but the Project 8 has real air intakes on the sides.
Old Nov 14, 2018 | 08:03 AM
frostysauce's Avatar
For the pre-2018 MY the inner opening on the front bumper is directly in front of the airbox. With aftermarket intakes, a few holes drilled between the honeycomb will provide fresh air to the filters and be pretty much invisible (the honeycomb is pretty deep).
Old Nov 14, 2018 | 08:53 AM
Stohlen's Avatar
Sure. But they may have made ducting behind those vents to direct air at the brakes, or be concerned about frontal surface area for cooling and decided to leave them open. Aero dynamics is an extremely complex thing and varies wildly based on your goals for the vehicle. Top speed, fuel economy, handling and cooling all require completely different aero strategies. It’s a balancing act and can result in some funky designs to get everything right. Add in US crash standards and it’s really a mess.
Old Nov 14, 2018 | 03:53 PM
Paul_59's Avatar
Banned
so either open these and direct towards discs for cooling or engine air inlet or don't have them.
My personal view is these fake vents are tacky styling features whether on F type or any other car.
I hate this aspect of my F types looks.
Old Nov 14, 2018 | 04:13 PM
Unhingd's Avatar
+1. Air dams can be very effective at reducing drag and lift. The best use for those “air intakes” would be for brake cooling. In fact, an OEM brake duct for that location was available for track use only, but later discontinued.
Old Nov 14, 2018 | 06:24 PM
Carbuff2's Avatar
Our '14 Convertible already has curved air baffles that mount to the lower control arms. They seem to direct cold air from under the car, to the brakes. So open 'grills' might not be necessary.
malc4d
Feb 13, 2015 05:52 PM
Japthug
Feb 12, 2015 03:16 PM
gregh
Jan 16, 2013 07:38 AM
Disco stu55
May 19, 2009 05:34 PM
SeismicGuy
Nov 11, 2008 04:46 PM
