Fault codes: P0089-64 and P0173-00
Old Mar 20, 2025 | 06:59 AM
JagMan987's Avatar
Default Fault codes: P0089-64 and P0173-00
My jaguar f type 2015 v6 S AWD has yellow motor light on for many months/years, but drives totally normally. Sometimes after fueling it has dissapeared before, but it has not gone away for 4-5 months now.
Yesterday I did full service and diagnostics said 2 fault codes:
1) P0089-64: Fuel Pressure Regulator Performance
CHATGPT: Meaning: This code is related to the fuel system. Specifically, it indicates that the fuel pressure regulator performance is not within the expected range. The "64" part usually refers to a specific issue within the system, such as a performance fault or a malfunctioning component.
2) P0173_00: Fuel Trim Malfunction (Bank 2)
CHATGPT: Meaning: This code refers to a fuel trim issue, specifically on Bank 2 (which is usually the side of the engine with cylinders 4, 5, 6 on a V6 engine). Fuel trim refers to how the engine control unit (ECU) adjusts the air-fuel mixture. A malfunction here can lead to poor fuel efficiency, rough idle, or increased emissions.
Has anybody had similar codes and whats the possible issue. The service told me that they don't exactly know whats wrong and theres no real point changing everything. I also changed spark plugs, ignition coils. They deleted the code but it came back immediately. Car drives normally in my opinion, no smell, no smoke.
Old Mar 20, 2025 | 07:19 AM
Carbuff2's Avatar
Did you take a picture of the spark plugs you removed? Would be interesting to see if there is any difference in appearance.
Injector failure is common, hence JLR extended the warranty in the USA and Canada.
A leaking injector would have made the 'bad' side look 'rich'. The electronics may be trying to compensate...and initiating the yellow warning.
Old Mar 20, 2025 | 08:41 AM
clubairth1's Avatar
Community Influencer
Dump the garbage AI.
This forum has mountains of information specifically for your car.
It's the best information source available.
Why would you drive for years with a check engine light on?
Old Mar 20, 2025 | 08:48 AM
JagCode3's Avatar
@Carbuff2 Can you tell us more about the warranty extension for the fuel injectors? First I've heard of it.
Old Mar 20, 2025 | 10:54 AM
DJS's Avatar
DJS
Perhaps CarBuff is referring to the extended warranty on O2 sensors? Interestingly, both of these codes override the usual P0430 O2 error. That’s probably where I’d start, and the fact that the O2 sensors have a 15-year warranty on the V6 helps.
Here’s the JLR OBD2 guide.
https://www.dropbox.com/scl/fi/p52g7...=j0zw8nnz&dl=0
Here’s the O2 sensor warranty.
https://www.dropbox.com/scl/fi/z4k4i...=ga81ckvh&dl=0
Old Mar 20, 2025 | 12:44 PM
JagMan987's Avatar
Unfortunately I disnt take a picture. But they also disnt tell me that something was really wrong.
I’ve driving becouse nobody (average sevices) could not tell me whats wrong and told me to just drive the car since nothing is exactly wrong with driving it. The official dealer is far away.
I live in Europe.
As I understand the most probable couse to start is to change the 02 sensor? And theres no warranty in Europe, right?
Old Mar 20, 2025 | 01:25 PM
Carbuff2's Avatar
D'OH Yes I meant the O2 sensor extended warranty.
Needed more coffee this morning!
Thank you @DJS for furthering the conversation.
Old Mar 14, 2026 | 07:50 PM
kevin_jag's Avatar
@Carbuff2 I'm looking at that OBD doc you shared (thank you) and it looks that the code 'P2089' overrides the O2 sensor code, but 'P0089' does not. Am I reading the doc correctly? Thanks in advance, I'm chasing the same P0089 code as OP and my mechanic has me looking at the LP fuel pump
Old Mar 23, 2026 | 10:23 AM
RoverJoe's Avatar
What's your VIN? I can probably offer some more input on the faults and what to check.
Have you considered having a dealership diag the car?
Stuart Satter
Dec 31, 2020 02:19 PM
RoyLittle0
Sep 5, 2018 04:48 AM
razorboy
Feb 7, 2017 03:34 PM
05Blkstr
33
Dec 19, 2011 10:30 AM
Abe Mirza
Jan 30, 2010 10:41 AM
