Fixing the system date / GPS
Old Nov 23, 2025 | 10:36 AM
woohoo's Avatar
Question Fixing the system date / GPS
The GPS in my 2018 F-Type R has been busted for awhile (the car thinks i'm stuck in some place a few hundred miles away and doesn't move).
However, I've recently updated my infotainment (changing CCF and screen from 8" to 10") to be able to do Android Auto / Car Play, and AA doesn't like when my date is stuck at 2014. Unfortunately it looks like I can't change the date manually, and it may be linked to the GPS?
Would anyone happen to know if it is possible to change the date in the infotainment manually? If not, I'm taking a look at how to replace my antenna to fix the GPs issue (and hopefully the date?) There are several antenna available https://parts.jaguarpalmbeach.com/sh...sembly=6471456 - I was wondering how to choose which one to get? Radio/cell/etc all work, just not GPS. Thanks!
Old Nov 23, 2025 | 12:08 PM
alchemystic's Avatar
On the stock nav screen, date and time are manually adjusted in system settings and are not linked to GPS.
Old Nov 24, 2025 | 09:29 AM
woohoo's Avatar
Thanks for the reply - currently I have the stock system, just the updated screen. Unfortunately while I can change adjust the time (seemingly within +/- some number of hours of what it thinks is the current time), I cannot adjust the date.
If not the GPS module, some have suggested it might be linked to the cell connection, although that seems to be ok (you can see the 4G bars in the upper right)?
Old Nov 24, 2025 | 09:45 AM
RoverJoe's Avatar
Community Influencer
GPS is where the time pulls from, your GPS antenna is shared for the NAV and Telematics, different from the GSM/cell antennas in the bumpers. I can help you with some testing steps if needed, but it may be an issue with the TCU. Can you adjust the date through the IC?
Old Nov 24, 2025 | 10:37 AM
Vasara's Avatar
Try to turn Auto OFF. (between Time format and Date format)
By my understanding then you should able to set it manually.
Old Nov 24, 2025 | 12:52 PM
woohoo's Avatar
Thanks! How would I go about testing this? The only location I've found where I can attempt to adjust the time/date is the setting screen above, but unfortunately that doesn't seem to work. If there's another way I'm happy to try it!
I also do have Pathfinder, so if there's a test or way to check through there, I can also try that out.
Old Nov 24, 2025 | 01:02 PM
RoverJoe's Avatar
My preferred method is to pull the antenna wire at the TCU and verify it's a good circuit. Do you have any faults in the TCU? I will find a picture for you to show where to test.
Old Nov 24, 2025 | 01:12 PM
RoverJoe's Avatar
So the best test is to start at the TCU or IMC, although it might be easier to get into the splitter. Kinda depends if your car is a coupe or vert. The splitter sends the same antenna signal to both the TCU and the IMC, because it's used for both. Connector A coming in to the splitter from the antenna would be a good choice. The cables are Coax, so you remove them and gently test from the center pin to the surrounding screen wire, you should get a couple thousand Ohm value through the antenna, it's 10k for the GSMs, not 100% sure on the GPS but should be similar, you are mainly looking for a non-open or shorted. From there you can decided if it's an antenna issue, wiring, splitter, or modules.
Old Nov 24, 2025 | 01:15 PM
RoverJoe's Avatar
I'm not sure what useful info Pathfinder has anymore, we haven't used it in 2 years in the dealerships. If you have your VIN I can look the car up on Topix and see if there's any specific info.
Old Nov 24, 2025 | 06:03 PM
woohoo's Avatar
Ah wow, thank you for the detailed schematics! The car is a 2018 coupe - the TCU / IMC are in the center back section between the seats? I was going to either start there or the sharkfin antenna on the back hatch.
Appreciate all the help
olefre
Mar 29, 2025 10:57 AM
thomasag
Jun 11, 2021 04:53 PM
Rick'sJag
Mar 8, 2018 05:41 PM
flycasterwa
May 1, 2012 08:55 AM
sgparnes
Jan 26, 2012 06:30 AM
