Fob hardware Key to open Door does not work
Old Mar 14, 2023 | 01:51 PM
bigbadorange's Avatar
Default Fob hardware Key to open Door does not work
I recently had battery issue and discovered neither key in my fobs work on the door. The keys look good, and look the same, but neither will turn once in the door. Any tricks that I may be missing? Is it possible the keys were wrong from the factory? I can't imagine BOTH fobs were replaced and somehow the keys were not switched.
Old Mar 14, 2023 | 02:03 PM
Carbuff2's Avatar
Tried some graphite lubrication, like Lock-Ease?
Amazon Amazon
ANOTHER reminder for everyone to lubricate and try the keys yearly! Thanks for reminding me....
Our used F came with two fobs but only one emergency key. They are available through a dealer, by VIN.
EDIT: Just tried ours, THANKS. Also, be aware that if the little 'handle' on the key is at 90 degrees, the key won't turn because it isn't in far enough...
Be careful of the door's paint!
And, also lubricate the other emergency keyhole near the driver's door latch mechanism.
Old Mar 14, 2023 | 02:40 PM
luricating the lock, hadn't thought of that, I will give it a try. I guess I will order a new key through dealer if its not too much to see if somehow the wrong keys are in my fob.
Old Mar 14, 2023 | 03:48 PM
uncheel's Avatar
The most common issue is not having the key FULLY inserted.
Old Mar 14, 2023 | 06:41 PM
OzXFR's Avatar
Yep, you have to push that key in very hard to get it to go in all the way. There is an initial detente but that's not fully in, you have to push it past that spot.
Artie
Mar 25, 2022 08:42 PM
asuboy75
XF (X260)
Jan 17, 2021 08:40 AM
MonacoDK
Feb 1, 2016 09:33 PM
ratty62
Jul 17, 2014 10:04 AM
bsmarsh333
Dec 21, 2008 10:19 PM
