Front Washer Bottle Location
Old Apr 18, 2018 | 11:30 AM
4x4uk's Avatar
Default Front Washer Bottle Location
anyone kow where the front screenwash bottle is located and where piping from rer bottle runs.
Had car parked on a fairly steep slope today and there was a puddle under drivers side wheel. Warning on dashboard for low washer fluid which was just refilled on saturday.
So I am suspecting a leak somewhere
Old Apr 18, 2018 | 11:40 AM
IronMike's Avatar
Washer reservoir is under the rear boot lid, to the right of the latch.
Yes. The REAR Boot Lid.
Don't know where the line travels to get to the front of the vehicle.
Old Apr 18, 2018 | 11:47 AM
4x4uk's Avatar
there is a secondarty washer bottle in the front IIRC a punp pumps fluid from the rear to the front as the front bottle is not accessible normally
Old Apr 18, 2018 | 01:39 PM
DJS's Avatar
DJS
"The plastic, molded reservoir is located in the right (front) wheel arch,
behind the liner. It is secured to the body and front panel with bolts.
A boss on the reservoir locates into a bracket mounted off the A-pillar
casting and provides additional support.
The reservoir has 2 recessed holes in the side, which provide location
for the windshield and headlamp washer pumps. The pumps are push
fitted into grommets, which seal the pumps in their locations. The
windshield washer fluid hose is integrated into the harness and so
follow it's routing. The headlamp washer hose, from the reservoir, is
routed over the wheel arch and across the body between the
headlamps.
A hole with a grommet in the side of the reservoir provides the
location for the fluid level sensor."
See section 501-16 from this 480MB document which OzXFR posted. It's specific to the V6, though presumably the V8 is the same or similar.
https://www.dropbox.com/s/t2hfjv7bas...anual.pdf?dl=0
Old Apr 18, 2018 | 02:03 PM
4x4uk's Avatar
many thanks djs
makes sense, watter is dripping from wheel arch liner on drivers side fo either so least It looks like the fault is in or around the washer bottle
Old Apr 18, 2018 | 04:47 PM
Suaro's Avatar
So there are two pumps? one to move the solution from the rear reservoir to the front reservoir and then a second pump to move the solution from the front reservoir to the windscreen? Doesn't seem like the Jaguar way of doing things. That second pump adds cost and weight and complexity.
Old Apr 18, 2018 | 05:08 PM
DJS's Avatar
DJS
There's a pump on the rear tank, to transfer fluid to the front tank, based on level sensors.
There are two pumps on the front tank - one for the windshield, one for the headlights.
3 pumps.
Old Apr 18, 2018 | 05:12 PM
Suaro's Avatar
Maybe it’s the English weather. Didn’t the E-Type have three wiper blades?
kfisher1031
Apr 20, 2018 11:33 AM
carlinasj
Dec 8, 2014 09:45 PM
Greg in France
Jun 7, 2013 01:56 PM
pmsoft85
Jan 1, 2009 06:47 PM
