H&R Lowering Springs on Base F-Type
Old Nov 1, 2019 | 03:35 PM
  #41
powerhouse's Avatar
Originally Posted by Jaggyx
I believe they only make one part number for the V6 springs.
https://eibach.com/us/i-7871-pro-kit...4-springs.html
Do some shopping around though. They can be had for much cheaper than $600.
Found theses , as you say for the V6, around $280 or €250, cheap enough, whether they fit the 2.0 , ill have to see does the 2.0 have the same part numbers for the OEM springs as the V6
https://www.tunershop.co.uk/suspensi....html?limit=24
Old Nov 5, 2019 | 02:28 PM
  #42
powerhouse's Avatar
Originally Posted by FType17
No wheel spacers (that's something I find idiotic) but I had the wheels custom made to include an extra 10mm of offset so it's like having 10mm spacers all around
Eibach springs installed along with 15mm spacers. Still a slight rake, but overall, really happy with the height.
So guys going for the Eibach,s like yours , will I still have a bit of clearance now I have the 15mm spacers all round and 305,s rear and 265,s front, at present the gap at the rear is 50mm the front 35mm
Old Nov 5, 2019 | 02:38 PM
  #43
powerhouse's Avatar
This is the gap front and rear
Old Nov 5, 2019 | 07:42 PM
  #44
Unhingd's Avatar
Doesn’t matter what springs you have: if you hit a big enough bump with 305 tires and 15mm spacers , you’ll grab the fender lip.
Old Nov 5, 2019 | 10:15 PM
  #45
Jaggyx's Avatar
+1. Large highway dips will cause you to rub.
Old Nov 6, 2019 | 05:44 AM
  #46
powerhouse's Avatar
Thanks for the feedback guys, im not a high speed driver, so its more the look i want, if worse comes to worse I can remove the spacers and see what happens, jaggyx your drop is what i am looking for, the front might not drop anything due to the lighter engine, there might be a discounted set of springs available if it dosn't work, will give it a go anyway.
Old Nov 6, 2019 | 11:52 AM
  #47
Jaggyx's Avatar
Even hitting freeway dips at 60 mph will cause the rub. That being said, I since have cut the rear spring half a coil as the coils at the top do not provide anything other than spacing. If I were to do it again, I'd probably go with H&R springs even though you do give up some initial travel.
Old Nov 6, 2019 | 12:26 PM
  #48
powerhouse's Avatar
Thanks jaggyx, seems im going to be the guinea pig for 4 pot owners, H&R would certainly be to low, is you car much lower now since you cut half the coil
Old Nov 6, 2019 | 12:39 PM
  #49
Jaggyx's Avatar
Here's the latest stance.
Old Nov 6, 2019 | 02:51 PM
  #50
powerhouse's Avatar
wow thats looks stunning and menacing , so can you tell us your setup, springs etc as is, your wheels look like they sit out same as mine with the spacers, what size tires you running
Stuart@VelocityAP
Apr 26, 2024 12:38 PM
jaguny
Apr 12, 2019 09:43 AM
Stuart@VelocityAP
Jul 19, 2015 09:14 PM
Stuart@VelocityAP
Jun 23, 2015 02:25 PM
Stuart@VelocityAP
Sep 4, 2014 10:39 AM
