Has anyone removed the front bumper?
Old Sep 26, 2018 | 05:08 PM
Jaggyx's Avatar
Default Has anyone removed the front bumper?
Any tips and tricks? How long should it take?
I plan on replacing this piece:
Thanks!
Old Sep 26, 2018 | 05:16 PM
Unhingd's Avatar
Thanks!
less than 30 minutes to remove the nose.
Old Sep 26, 2018 | 05:17 PM
Jaggyx's Avatar
Thanks! Have you done it? Any steps you can share? From what I gather, a bunch of washer fluid stuff has to be removed...
Old Sep 26, 2018 | 05:23 PM
Unhingd's Avatar
After the bolts are removed and the nose is pulled forward about 6”, you have to disconnect two of the proximity sensors (those in the cross bar) and pull the hoses off the 2 head lamp washers. All very straight forward.
Old Sep 26, 2018 | 05:25 PM
Jaggyx's Avatar
Awesome. Thanks a lot!
Old Sep 26, 2018 | 05:39 PM
DJS's Avatar
DJS
I believe someone posted comprehensive instructions a long time ago. I found this...
https://www.jaguarforums.com/forum/f...6/#post1189897
Old Sep 26, 2018 | 08:34 PM
Jaggyx's Avatar
The clips on the grills are ridiculously tough. Removing the bumper has taken 10% of the time so far.
Old Sep 26, 2018 | 11:06 PM
Jaggyx's Avatar
By the way, for anyone referencing this in the future -- use a heatgun to heat stretch the clip openings wider. Each clip will take about 5 seconds of heating. Once the grill is off the car, heat each opening again to melt the plastic back to the original size.
Old Sep 27, 2018 | 01:36 PM
Itismejoshy's Avatar
as noted, its 15 minutes to remove the front bumper. Super easy, mine is off every other weekend at this point. once you do it once you will not be concerned with doing it again.
Sean W
Aug 14, 2020 07:07 AM
razorboy
Aug 10, 2016 04:08 AM
Fstbmw1
Nov 27, 2015 03:08 PM
kthrash
25
Jun 22, 2011 09:49 AM
03jaguardown
Dec 25, 2009 02:00 PM
