How Do I Get To My Subwoofer?
Old Jan 13, 2017 | 09:01 PM
Tahoe Dave's Avatar
Default How Do I Get To My Subwoofer?
I have a 2015 MY that has just started in with the dreaded subwoofer rattle. It is coming from the speaker located behind the drivers seat. Taking the car in to the dealer is at best inconvenient. That said, can someone give me the step-by-step directions to access the speaker. I believe that there is a good chance that I can either tighten or install some stereo sound deadening material to solve my problem
Thanks in advance...
Dave
Old Jan 16, 2017 | 08:10 AM
Cambo's Avatar
Coupe? Convertible?
Old Jan 17, 2017 | 08:53 AM
Tahoe Dave's Avatar
Originally Posted by Cambo
Coupe? Convertible?
Coupe and thanks for checking-in!
Old Jan 18, 2017 | 04:23 PM
Cambo's Avatar
I have only pulled apart a convertible to access the rear speakers, but I imagine a coupe will be similar, except there are no rollover hoops?
Short explanation for a convertible you need to;
Remove the plastic sill trims that run along the bottom of the door jamb.
Remove the the plastic trims where the seatbelts go in.
Remove the speaker grilles in the trim panel behind the seats
Remove the rollover hoops (bolts accessed when the speaker grilles removed)
Remove the bulkhead panel, it just lifts out once the rollover hoops are removed.
I checked my files on this laptop, don't have a specific instruction for a coupe, but that's it for a convertible...
Old Sep 28, 2017 | 01:36 AM
15FTypeR's Avatar
Has anyone else done this yet on the coupe and can give more details of the steps? I don't want to break anything. I just need access to the wires going to the subwoofers, meaning anywhere between the 770w amp and the speakers would be fine. 99% of the time spent on the upgrade project is figuring out how to get the car apart safely.
Old Sep 28, 2017 | 08:31 AM
amr42's Avatar
The remaining 150% of the time is spent (we all know these projects take far longer then expected) putting it back together and figuring out what to do with all the spare bits...
We need a sticky or section on 'How to take apart' this piece. Especially inards. Maybe Topix access like some give us here is the real answer...
Old Sep 28, 2017 | 12:00 PM
15FTypeR's Avatar
I bought the topix access for a week, and the info on disassembly of this area of the car was ... nearly useless. I'm hoping to get much more detail and insight. Service manuals for other vehicles I've had were much more helpful.
Old Sep 28, 2017 | 06:30 PM
OzXFR's Avatar
I looked through my copy of the service manual for this procedure, and it looks very messy and complicated, but doable.
You have to completely remove the seats from the car, then remove almost all of the side and rear trim pieces, and THEN you can access the speaker panels behind the seats which you remove to access rear speakers/sub-woofers.
As said before it shows you what to remove and a rough picture or two of where the clips are (and lots of warnings!) but it's very light on for nitty gritty "how do I do this?" details.
Old Sep 29, 2017 | 07:57 AM
domino_z's Avatar
hmmm i'm confused here - the speaker grilles are set in the carpet, can't you just pull the grilles off to get access
my grille is rattling under heavy base too
this is how the speaker grille attaches - i put this pic together using the rattle fix pdf
the red markers are tabs which slide in behind the carpet, the blue markers are push clips, so looks like you use a trim tool and start at the inside top edge to pop the push clips free then walk it out up and towards centre console
Attached Thumbnails How Do I Get To My Subwoofer?-untitled.jpg   How Do I Get To My Subwoofer?-untitled2.jpg
Old Sep 29, 2017 | 05:55 PM
15FTypeR's Avatar
@domino_z thanks for the diagram. I do not believe this opens up enough space to access wires, but good to know they come off. I spent a little time trying to remove it and only achieved anger and sore fingers so far, so I can not yet say for certain if this will get me to the wiring. Disassembling things on this car is....interesting.... I still believe I may have to remove the whole panel to access anything there, but I'll continue to curse at this part and try to make progress.
Old Aug 19, 2020 | 03:43 PM
tec-9-7's Avatar
I hate to grave-dig a thread, but I'm well out of warranty on my F-Type roadster and I've got this rattle. Are there any pics of this procedure along with the proper tools to use for it? I've pulled interior panels off of other cars, and I almost always manage to either break parts on the panel or break the fastners.
Old Aug 21, 2020 | 08:55 AM
malbec's Avatar
Video here thanks to member Paul Calvert...
#217 of this link..part 3 rear bulkhead trim...But it is a Coupé! Hopefully not too dissimilar.
https://www.jaguarforums.com/forum/f...-146775/page6/
Old Aug 21, 2020 | 09:55 AM
tec-9-7's Avatar
You are AWESOME!
tcharron
May 29, 2024 10:25 PM
MattArnold
May 29, 2020 10:19 PM
sktslls
Dec 20, 2013 08:03 AM
lastgoodbye
Dec 18, 2013 01:25 PM
JessN16
Jan 29, 2013 04:22 PM
