Interior Fust Box question
Old Aug 11, 2021 | 04:38 PM
TX69XKE's Avatar
Default Interior Fuse Box question
I want to wire in my dash cam and thought from reading another thread that there was a fuse block in the passenger foot well. On my 2018 Coupe, the access panel at the very back of the foot well seems to be the location of several bus sockets (long white clip in multi-wire sockets) but no fuse block. Am I missing something or has the fuse block been moved?
Old Aug 12, 2021 | 02:02 AM
Borbor's Avatar
You can always go with mirror tap instead which is what i did and simpler IMHO to get switched power
Old Aug 12, 2021 | 07:38 AM
TX69XKE's Avatar
Originally Posted by Borbor;[url=tel:2427255
2427255[/url]]You can always go with mirror tap instead which is what i did and simpler IMHO to get switched power
where did you get the mirror taps? I have a Thinkware dad cam.
Old Aug 12, 2021 | 09:09 AM
DJS's Avatar
DJS
Did you look under the carpet of the floor of the passenger footwell? Took me a while to find it the first time.
Old Aug 12, 2021 | 10:03 AM
TX69XKE's Avatar
Originally Posted by DJS;[url=tel:2427344
2427344[/url]]Did you look under the carpet of the floor of the passenger footwell? Took me a while to find it the first time.
I found an access panel at the back of the passenger footwell under the carpet. It’s about 12 inched by 10 inches, but under it I found a handful of buss connections, but no fuses. Is there a second panel I missed?
Old Aug 12, 2021 | 07:13 PM
Borbor's Avatar
there are plenty on amazon or ebay but i just made mine myself.
here is the thread about how to wire it
https://www.jaguarforums.com/forum/f...nstall-106666/
for a dashcam you will need a cheap 12v to 5v step down converter as well which will fit under the mirror cover
Old Aug 15, 2021 | 06:54 PM
Thunder Dump's Avatar
I have this same question. There is no fuse block under the passenger side footwell in my MY18 vert. I have the same module as TX69XKE, which looks like this:
Old Aug 15, 2021 | 07:24 PM
Never mind, I found them:
ChuckTrish1
Mar 15, 2021 10:52 AM
tigerwoods
Aug 13, 2020 03:47 PM
SamtheSham
May 7, 2020 08:16 AM
michaelodonnell123
Jan 7, 2016 11:43 PM
mrtalkradio
XJ40 ( XJ81 )
Feb 24, 2012 05:36 PM
