Launch control
Old Aug 15, 2023 | 07:34 AM
  #61
Portlander's Avatar
Originally Posted by JCtx
Indeed, but that's not what the instructions you posted said, hence our confusion. They said to press the gas pedal lightly, and when the launch message says it's ready, to release the brakes, then floor the gas pedal. That's clearly just a brake-torque launch. But if it's like you just described above, then it'd' be proper launch control. So for which model were the instructions you posted??? Just curious.
Exactly, something is not adding up and I'm getting annoyed that Cgo's car does something that mine will not. It has to be connected to New Hampshire's "live free or die" motto!
Old Aug 15, 2023 | 08:32 AM
  #62
jcb-memphis's Avatar
Be nice to your rear diff.....it is expensive to repair. I have a V6S with the same ediff and such as the R...the R's and SVR's have their torque exactly at the limit of the zf8HP70. Not a coincidence that from the factory the tuning is this way....I am quite sure Jaguar could have tuned the cars for more power...
Old Aug 15, 2023 | 09:10 AM
  #63
OzXFR's Avatar
Nup, the V6S doesn't have the e-diff, instead it has a mechanical LSD (while the base has an open diff).
And I'm fairly sure it's not the engine tune in play instead it's the TCM (transmission control module) telling the PCM (powertrain control module) to cut back on the torque under certain conditions.
Old Aug 15, 2023 | 10:03 AM
  #64
Thanks. Had read that the AWD V6S had the ediff but frankly am happy to have the mechanical if true....in theory easier to fix long term....in theory.....
Old Aug 25, 2023 | 06:37 PM
  #65
Portlander's Avatar
The next subtitle said to enable dynamic mode and basically do a brake/torque launch. This video was a test drive of the 2024 R.
dibbyandco
Oct 15, 2025 04:53 PM
Datkat
Dec 2, 2022 07:33 AM
Crovax
Jun 27, 2019 09:52 AM
FullChat
Feb 26, 2018 11:20 AM
