NAV Voice Guidance Not Working
Old Jan 13, 2015 | 05:53 PM
Lovemonet's Avatar
Default NAV Voice Guidance Not Working
The navigation voice guidance has worked since I picked up the car a month ago. Today, I cannot get it to work. I went to the Nav screen where you can turn the voice guidance on and off with the soft key and it is on. I checked the audio volume and it was OK. The manual indicates the soft key on the Nav screen is the only method for turning the voice guidance on and off.
Anyone else have this problem or know how to fix it? I live an hour from the dealer so don't want to make a special trip for this.
Old Jan 13, 2015 | 06:31 PM
Foosh's Avatar
On two occasions, I've had little glitches associated with the soft keys not responding. Both occurred within the first month I had the car, and on both occasions, I was able to restore all functions by shutting the car down and re-starting. Did you try that?
Neither of my issues has re-occurred in the last 7 months I've had the car.
Old Jan 13, 2015 | 07:50 PM
Unhingd's Avatar
You might also try a complete reboot by disconnecting the battery(s) for a couple minutes.
Old Jan 13, 2015 | 08:07 PM
Lovemonet's Avatar
Yes, I still have the problem after re-starting.
Old Jan 13, 2015 | 08:09 PM
Lovemonet's Avatar
Thanks, I will try that tomorrow.
Old Jan 13, 2015 | 08:33 PM
mshedden's Avatar
Just the negative terminal would probably do it.
If I had a nickel for every odd behaving device that was fixed by disconnecting the battery/power, I'd have a lot of nickels...
You'd think by now a hard reset option would be built into everything...
Old Jan 14, 2015 | 08:39 AM
DJS's Avatar
DJS
Wonder if it would be easier to temporarily remove the fuse for the nav system.
Old Jan 14, 2015 | 11:18 AM
Unhingd's Avatar
Probably
Old Jan 14, 2015 | 12:55 PM
Lovemonet's Avatar
I disconnected and reconnected the battery and the NAV voice started working again but I can barely hear it. If I turn the volume up the radio gets louder but the NAV voice does not and cannot be heard above the radio. Is there a way to turn the audio (radio, etc) completely off but still have the volume on so I can hear the NAV?
Old Jan 14, 2015 | 01:05 PM
Unhingd's Avatar
Check the owner's manual. You should be able to independently adjust the Nav volume through the interface.
Old Jan 14, 2015 | 01:23 PM
swajames's Avatar
This is my guess too. I suspect the navigation volume has been set to zero. It's an easy adjustment through the menu.
Old Jan 14, 2015 | 01:24 PM
F-typical's Avatar
Mine has changed the voice it uses without my intervention.
Old Jan 14, 2015 | 01:35 PM
DJS's Avatar
DJS
I didn't find any option to change voices in mine. On my Ford (completely different system), if I turn the volume know while the Nav system is talking, it changes the Nav volume not the radio volume.
Old Jan 14, 2015 | 01:44 PM
shift's Avatar
There's definitely an option to change the nav voice. It' under audio system settings from what I remember. OR you can change it when the voice nav is speaking with the volume knob. There's also an option to enable/disable voice nav.
Old Jan 14, 2015 | 01:46 PM
Unhingd's Avatar
Lovemonet, try this:
Select 'Setup' from the touch screen Home menu, then select 'System'.
Select Volume presets, then use the +soft key alongside the Navigation.
If there is no option to select volume for navigation, try setting the volume higher for the Parking aid. I get the feeling those two volumes may be connected as they both mute the phone and radio volumes when they come on.
Old Jan 14, 2015 | 01:47 PM
DuhCar's Avatar
I didn't find any option to change voices in mine. On my Ford (completely different system), if I turn the volume knob while the Nav system is talking, it changes the Nav volume not the radio volume.
Same on my BMW.
Bcrary3
Sep 12, 2021 05:41 AM
Dz1rfj
Sep 16, 2015 03:44 PM
KarimPA
Sep 12, 2015 08:15 AM
philwarner
Sep 5, 2015 10:05 AM
pegasus3710
Sep 5, 2015 09:40 AM
