New to the forum
Old Apr 28, 2021 | 01:38 AM
6speedjag's Avatar
Default New to the forum
Hi all, I am new to this forum but not new to the Jaguar world. I finally bought a MY2016 black/red interior 6 speed V6S and love it.
Happy to be part of this forum. Currently located in Miami FL.
Old Apr 28, 2021 | 02:31 AM
scm's Avatar
scm
Welcome aboard!
Old Apr 28, 2021 | 08:37 AM
SinF's Avatar
Welcome to F-type ownership, you are now a proud owner of a Jaaaaag minus Lucas and oil leaks. As F-type shares a lot of mechanics with earlier Jaguar XKR, even early F-types benefit from 'mid cycle' mechanical updates and are considered reliable. As no car is perfect, there are few common themes and re-occurring flaws that you will have to deal with.
Issue 1: Cooling system and plastic coolant piping - unfortunately a number of plastic coolant pipes in the engine bay were made from material that becomes brittle with age and splits at the seam. This was made worse by adding an insulated engine cover that traps heat in the engine bay. Some of these coolant pipes are in the engine valley, requiring removal of supercharger to replace. Parts were updated around 2017 to seam-less design to prevent splitting, but your F-type does not have them installed from the factory. These can fail two ways - sudden failure where you dump all coolant and overheat the engine or slow leak. Sudden coolant loss is more dangerous as in-dash engine temperature indicator displays a running average and not instant engine temperature measures, delaying when the driver notified about overheating. So by the time you see the dash warning about overheating the engine have been cooking, potentially without any coolant at all, for a few minutes. Treat anything related to cooling system as an emergency, do not wait to pull over, shut the engine off, and open the hood. If you get coolant warning, have the car towed unless you can confirm it still has coolant. While this might be an overkill, I also ask my garage to pressure test cooling system every year prior to storing it for the winter. Additionally I permanently removed engine cover and it had measurable effect on reducing engine bay temperature.
Issue 2: Engine oil and sludge. AJ133 V8 and AJ126 V6 engines in F-type use direct injection (DI). DI means these engines are prone to developing sludge on intake valves if oil is neglected. These engines also use oil pressure to control variable timing. All of this means that things go bad very quickly when the oil gets dirty. Fortunately, frequent oil changes using spec oil shown to largely mitigate sludge. It is very crucial that you stay on top of oil changes and use spec synthetic oil with specified additives. Also keep in mind AJ133 V8 doesn't have low oil pressure sensor (yes, you read it right), this means you can run the car dry and it will not warn you. All of this means that you have to be religious about changing oil and monitoring engine oil level.
Issue 3: Injectors. AJ133 V8 and AJ126 V6 engines in F-type use direct injection (DI). This system has two stage fuel pumps and high-pressure injectors. This setup means that running out of gas has a chance to damage pumps, so take care not to do that. Injector failures are unfortunately known to happen where the whole rail has to be replaced, but can be mitigated with regular use of PEA-containing injector cleaning. I recommend running PEA fuel additives like BG 44K annually or budget for injector replacement in a couple years.
Issue 4: Battery and charging. When you plug anything into OBD port, power management control module is known to get glitched and not completely power the car down. This in turn runs the main battery flat as the car never fully shuts down. To fix this, you need to disconnect the main battery to reset the power control module. Dead battery in a locked car is a huge inconvenience, as you need power to open the trunk to access the battery, so it can lock you out of the car and it is nuisance to get it resolved. My suggestions: a) know emergency unlock procedure (with mechanical key hidden in the fob) and boost points in your engine bay b) avoid using OBD readers or assume it will glitch and reset PCM after each use. You can visually tell that the car did not fully power down if emergency triangle stays illuminated 10 minutes after you locked the car - this means PCM is glitched. More so, having marginal battery on these cars is known to trigger all kind of fault codes, so if you suddenly see multiple dash warnings about unrelated things... don't panic, it just might be a marginal battery.
Issue 5: Clutch. If your 2016 car has original clutch, it is about to go. Read details in this thread for details: https://www.jaguarforums.com/forum/f...action-158861/
While this is not a fault or mechanical issue, make sure to stay on top of transmission, differential, supercharger oil, brake fluids and engine coolant changes. Low miles on your car does not mean that original fluids are fine - as they degrade both with use and time. Unless you have records from PO, assume that nothing other than oil changes was done (many people treat lease cars as a rental). This means you have to catch up on all other fluid and filter changes. Changing engine oil is critically important, but there are other fluids and filters that also have to be regularly changed. Based on the year of your car, you are overdue on coolant and brake fluid changes and due on transmission fluid change.
Old Apr 28, 2021 | 08:28 PM
6speedjag's Avatar
Default Thank you!!
Thanks, and thank you for taking the time to let me know about all these issues. I really appreciate it, and am happy to be part of this forum!!!
Old Apr 28, 2021 | 09:27 PM
Hell Cat's Avatar
Welcome! The 6 speed is such a cool choice
Old Apr 29, 2021 | 11:03 AM
6speedjag's Avatar
Thank you!!
Old Apr 29, 2021 | 02:01 PM
lizzardo's Avatar
If you find the shifter throw to be a bit longer than ideal, there is a remedy. The topic goes back more than five years. If you've got abundant free time you can see the saga:
https://www.jaguarforums.com/forum/f...anyone-151101/
And as SinF mentions (Issue 5) you should be prepared for a clutch/flywheel replacement. It may have already been done and the money can stay stashed in the cookie jar but if it's original, it's on borrowed time.
Old Apr 29, 2021 | 02:34 PM
Jaguardeseo's Avatar
Amazing information, so useful, thanks!!
Old Apr 30, 2021 | 01:18 AM
6speedjag's Avatar
thank you, I started reading it some days ago and will finish reading it soon. As for the shifter throw I think you are referring to the custom short shifter kit. Very interesting.
The clutch slips when shifting to fast, as of now I have done 3000 miles with no issues when giving it a couple more seconds between gear changes, hopefully it last a bit more. Other than that I love the Jag!
Old Apr 30, 2021 | 01:22 AM
6speedjag's Avatar
Today I tried the injector cleaner, thank you again for letting my know. Do you have any other recommendations for the other fluids and oils mentioned above?
JAL
Jul 13, 2020 01:54 PM
cbroth1
Dec 18, 2015 09:21 AM
Jagnit
US Northeast
Jun 24, 2014 07:51 PM
Jagnit
Apr 6, 2014 10:46 AM
