new owner, question about Blind Spot Information System
Hey guys, new Jaguar F type v6s coupe owner here. I was wondering if anyone has experience installing aftermarket blind spot monitor systems on the F type. My car didn't come with this option from the factory and I was wondering if I can install aftermarket ones, my dealer says he cannot do it using factory parts.
Also, anyone get aftermarket tires/rims for the car? What spec do you guys recommend for the tires? I want to stay at 19 as the car is a bit bumpy for me, should I go wider than 245/275 or stay as is?
Thanks for your time, Bo =D
Also, since you have the S, you should have adjustable suspension settings. Have you attempted to dial those in for your preferred ride?
Hello, thanks for the reply.
It would be awesome if you can calculate the offset for me, for my previous cars (e92 m3 and b8 s4) I just browse through the forums and use the settings people recommend. Are you saying 55/38mm is the way to go or if there are other numbers I need to consider. I just want more grip.
I haven't started messing around with the adjustable suspension settings, just got my car. Do you mean going on a suspension/alignment store and going on a lift or doing in-car suspension settings? I just got my car 3 days ago and havn't had the time to look into these things yet.
Thanks again
Thanks again
Thanks again
Thanks again
Thanks again
Thanks again
My recommendation if you really want to stay with 19" wheels:
Front: wheels 19x9" (55mm offset) tires 255/40-19
Rear: wheels 19x10.5 (38mm offset) tires 295/35-19
This will keep the outside tire diameter relatively unchanged.
Regarding suspension, I do not have the F-Type in hand yet but I understand the ride can be adjusted from the menu on the display. Others on this forum will know better and should be able to advise you. If you can get the suspension set to your satisfaction, I would strongly advise going to the 20" wheel for the wider tires. Factory OEM take-offs are readily available at a reasonable price.
Configurable dynamics was an option in 2014 (which I didn't get.) Looks like it's standard on the 2016 V6S. Don't know about the 2015. What year do you have?
The OP is in China, not the US. Standard options vary by country.
It is not standard on the 2015 V6S.
hey guys, I checked the extra features on the center console, I do not have the configurable dynamics. I am going to ask my dealer if it can be retrofitted, I am guessing its just softwares. The f types here in China all have very strange options. The red caliber brakes on the S are extra cost options, most of the cars don't have navigation systems or blind spot monitors.
lhoboy, why do you recommend the 20s for wider tires? Are they more effective with wider tires? I am a newbie with these things. My audi b8 s4 had the stasis touring package with 20s. The car handled well and looked really nice but roads in China are horrible and I am worried about the sidewall of the tires if I go 20s.
1. It allows you to go to a lower profile tire (shorter sidewall) for the same outside wheel diameter.( 35 front/30 rear instead of 40 front/35 rear)This reduces tire chatter around high speed turns and will provide greater traction.
2. Jaguar offers a wide range of optional 20" wheels with the right widths and offsets. I don't know how many aftermarket 19" wheels will have the right specifications. Also, at least here in the US, low mileage used 20" Jaguar wheels are readily available at good prices.
As you suggest, the 20" wheels, however, may not be practical because of the road conditions in China.
Here in the US, on the V6S the red calipers are also an additional cost (same exact caliper as the black ones)
2 reasons for going to 20" wheels:
Ya I am going to go for 19s, just gotta find the right aftermarket 19s like you said. The red calibers here in China are actually an upgrade (bigger) than the yellow standard ones.
On another note, what do you guys use for tire pressure on the stock 19s? I read 36 all around? Is it better to go slightly higher on the front because the car is a lil bit front baised?
Interesting: here in the US, the yellow calipers are the $13,000 high-end ceramic brake option.
BrentGardner
29
Dec 16, 2024 12:13 AM
Robert1968
Jun 24, 2017 11:16 AM
