no ignition ! no light in dash
Old Oct 10, 2023 | 02:00 PM
rlx89's Avatar
Default no ignition ! no light in dash
after the car was without a battery for 6 months, now the ignition does not turn on! the central locking does not work!
working just hazardlight, parking light and navigation !
Old Oct 10, 2023 | 03:22 PM
2018XF25T's Avatar
Clean both Positive (+) & Negative (-) battery cable terminals with sand paper. Then clean it with dry cloth. If the battery is not new do the same to the battery terminals. Now, attach the Positve (+) terminal first and Negative (-) to the battery. Then start the engine. Note: Battery must be fully charge. If it didn't start, have the battery tested (even though you bought it new) at any of auto parts store such as AutoZone, O'Reilly, NAPA , AAP. Battery test is free of charge on these outlets nationwide.
Old Oct 10, 2023 | 03:50 PM
rlx89's Avatar
battery is newand fullcharge ! no ignition ! no car start ! no dash on
Old Oct 10, 2023 | 03:58 PM
2018XF25T's Avatar
The car was running before, right? Then check the fuses. You must have a multitester to complete this task.
Old Oct 11, 2023 | 12:30 AM
rlx89's Avatar
i check all ... battery, fuse, key ... all !
Old Oct 11, 2023 | 03:55 AM
scm's Avatar
scm
Why was the car without a battery for 6 months?
Old Oct 11, 2023 | 05:35 AM
rlx89's Avatar
for change paint color
Old Oct 11, 2023 | 11:46 AM
2018XF25T's Avatar
If the central locking system does not work, could it be the Key FOB might not be communicating? Use only Duracell or Energizer (CR2032) coin batteries and buy only from a good known source.
How about using the other Key Fob that came with the car. See if that will work
Old Oct 11, 2023 | 03:11 PM
rlx89's Avatar
battery in fob is new ... where is located GWM ? gateway module ?
JTsmks
E type ( XK-E )
Apr 28, 2023 09:33 AM
Dan219
E type ( XK-E )
20
Mar 9, 2022 07:58 AM
HorvJag
31
Dec 27, 2021 07:32 PM
homeboy
XK120 XK140 XK150
Jul 16, 2021 10:13 PM
NathanDD6
May 8, 2016 02:11 PM
