Oil level question
Hello,
bought an F-type almost 2 years ago and mostly been lurking on these forums since.
Since you guys seem more helpful than my Jaguar dealer I guessed this would be a good place to ask.
The car in question is a MY2016 base coupe. Up to the first service the oil indicator has always been at the top of the gauge. After the first service it was also at the top of the gauge but has been slowly dropping (first service was in October 2016). Sometime in April/may this year it started showing the oil level at half (and the green OK, see on photo down). Since then it hasn't moved and I check it almost every couple of days.
I read in the manual that this is perfectly fine and that no oil should be added. I just wanted to check what you guys think about it?
Also, I put the VAP tune two days ago and have to say it completely transformed the car (also, thank to Stuart and Chris for dealing with my questions).
Here are also two photos of the car in random locations in Croatia, because why not
I've been OCD about my oil level as of late b/c of the thread here regarding oil starvation with the V8. I've found that the oil level can dramatically change from day to day, to even a few hours after checking. I took the first pic one day and the 2nd pic is the next day. The 3rd pic is an 1.5hrs after the 2nd pic.
Thanks for your answer Kief!
I just went to recheck the oil level and it's still at the same level. First photo was 10 minutes after parking (after a spirited drive), checked it now, exactly an hour after the last check, and it's completely the same.
I'm guessing everything is fine, just the oil OCD (as you call it) kicking in a bit.
Normal driving - you will be fine. However, if you intend to go racing I'd top it off.
Also, as Kief mentioned level reading can be inconsistent. I try to take reading on a completely cold car in the morning while it sits on a flat ground.
Hello,
Are you kidding me !!!!
WTF is wrong with a dipstick to check the oil....this is freaking ridiculous!!! Dammed if you do and dammed if you dont !!! Just pisses me off!!!
No, no. A dipstick would involve opening the bonnet and that's a big no-no in today's cars. Notice how they put the washer fluid tank in the back as well
soon only dealers will be able to open the bonnet...
I replied to a thread on the forum by a former F Type owner whose engine failed, the owner quoted his mechanic who stated the failure was due to oil starvation, I didn't see what I would consider conclusive evidence of the claimed cause of engine failure.
The thread did wander as is often the case, touching on oil level monitoring (minus dipstick)
My detailed answer on electronic oil level / temperature sensor on F type
is here
https://www.jaguarforums.com/forum/f...1/#post1760697
is here
Oh but you must understand that the washer fluid reservoir was installed aft for one reason only; Weight Distribution!
If you put that reservoir forward, under the bonnet, the car would handle horribly.
