Panoramic Roof Slider Sagging
Old Apr 28, 2026 | 01:36 PM
Totti's Avatar
Default Panoramic Roof Slider Sagging
Hi all,
The slider of my 2016 F-type R is sagging from one side. Upon inspection, the glue which was holdiing the fabric dried out. I asked the dealership service center for a fix, and they quoted $4300. They said they can't fix the slider alone, they will replace the glass roof, headliner and the slider.
Did anyone manage to fix this issue, or at least make at least less visible.
Old Apr 28, 2026 | 02:14 PM
WhiteTardis's Avatar
That is incorrect. The sunshade is available separately. Part# T2R36223.
https://parts.harperjaguar.com/oem-p...frame-t2r36223
Old Apr 28, 2026 | 06:36 PM
Valerie Stabenow's Avatar
Default Frame?.
Is that part number for the frame only? Drawing is somewhat ambiguous.
Old Apr 29, 2026 | 05:37 AM
TangledThorns's Avatar
That sucks it can't be easily replaced. Curious as to the glue drying out, was OP's F-Type garaged or parked outside?
Old Apr 29, 2026 | 05:54 AM
Nick-Type S's Avatar
I actually looked into this when looking at a car last year - it can certainly be replaced, but you need to remove the headliner, which means removing the side windows, and a few other things. If you have the time and technical competence, it shouldn't be a big deal!
Old Apr 29, 2026 | 06:25 AM
cpq100's Avatar
Is reglueing it an option? Maybe using a hypodermic needle filled with glue to get to hard to reach places?
Old Apr 29, 2026 | 10:42 AM
Default Check out the "related topic" thread...
a couple of good photos, if you scroll down to Related Thread or just search:
"Swapping for Panoramic Roof"
I installed the headliner in my 69 e and did use the hypo technique for a few areas that didn't glue. These were maybe 4x4 inch spots. I don't know that would work with the much larger area that the OP has to deal with.
The related thread has some photos of the inside and how the swap was done. I think I will check the glue on my Pano roof panel to get ahead of any loose areas that think they want to let go.
Old Apr 29, 2026 | 11:59 AM
If you up one level it says that the sunshade included. https://parts.harperjaguar.com/v-201.../body--sunroof
Old Apr 29, 2026 | 12:01 PM
Yup, assuming that your headliner is in good shape, that's all you need (unless there are misc hardware bits you're missing or that need refreshing).
You can find these second-hand as well for under $1000 USD.
Old Apr 29, 2026 | 12:17 PM
lizzardo's Avatar
One side window, anyway, so the headliner can be removed from the cabin. I recently dropped my headliner for other work but did not go as far as full removal, so left the windows in place. It was a pain, but would be less so the second time. Not that I'm in any hurry to do it again though. There would need to be a pretty good reason. I did not look to see how hard it would be to replace the shade, but I can't see removal of the roof glass as necessary.
randyb
Aug 2, 2025 10:03 AM
jry
Sep 7, 2022 02:00 PM
Dave Sather
May 24, 2022 04:46 PM
Bumble7755
May 15, 2020 06:54 PM
sanchez
Sep 20, 2017 07:38 AM
