Pops when changing gear (V6)
Old Jul 12, 2019 | 03:16 AM
Falkenhayn's Avatar
Default Pops when changing gear (V6)
I have a MY2020 V6 and nopticed that I only can get pops when changing gears if I do it manually. It's pretty easy, just change gears when you are above 2500rpm. However I saw some videos where the V6 also does this automatically when driving in S and Dynamic however it doesn't work for me. Is this normal? Does it only work automatically if I'm driving it very hard and even then it's not guaranteed?
Old Jul 12, 2019 | 06:26 AM
OnlySlightlyEvil's Avatar
Try dynamic, S shift, then floor it.
Old Jul 12, 2019 | 07:11 AM
RGPV6S's Avatar
I only get pops and crackles when I let off on the gas or when car downshifts in sport mode. During upshifts in auto mode nothing really and if upshifting with paddles just a shift burp.
Old Jul 12, 2019 | 07:30 AM
Falkenhayn's Avatar
Yes, I was talking about the shift burp/fart, but if your 2014 model doesn't do this in auto mode then it seems to be normal, maybe only when you push it really hard as evil said.
Old Jul 12, 2019 | 01:54 PM
Jklad's Avatar
To hear the pops and crackles in an auto, you’ll want to drive in manual mode. Give it around 40% throttle or more, then when you’re above 5000rpm let off the gas. You can do this in any gear, but will probobly hear it better in 1st-3rd.
Old Jul 12, 2019 | 02:17 PM
Unhingd's Avatar
Any higher gear than that, you’d be exceeding the speed limit anyway.
I know...that comment is irrelevant.
Old Jul 15, 2019 | 11:01 AM
StormtrooperFtype's Avatar
so you're not talking about the backfire/overrun pops, the Fart on upshift, typically known as a DSG fart. my v6s doesn't do it in auto mode S mode really ever, very rarely, but in manual it will do it basically 100% of the time on hard acceleration.
Old Jul 17, 2019 | 07:28 PM
uncheel's Avatar
I get less on upshifts if I'm running automatic, but it's reliably farty if I'm pushing at all and use the paddle shifters. (There's no automatic RPM adjustment for the gear change.)
Overrun pops happen in all modes when you back off, but will be a bit more pronounced in Sport mode (because it downshifts quicker than Normal), and even more so when you're using the paddles, since you're in complete control. (And, when it gets too quiet, just drop down another gear and start all over.)
To the OP, you'll should get more noise as the car gets broken in, so don't give up.
jcamp
Jan 16, 2020 01:04 PM
vettinrnd
Feb 14, 2012 07:34 PM
GoobeGustafson
Dec 10, 2011 11:59 AM
jcamp
Aug 10, 2011 07:41 AM
andemat2
Nov 7, 2009 02:47 PM
