Just making you aware, because my car ended up being a lemon, i am having to sell off all the 670 hp project predator upgrade package parts. I paid a cringeworthy $15750 for them, they are all listed individually but the total if you bought them all is under $8000. The quality of workmanship can be verified by even it's competitors at VAP. This js the preeminent company in the UK doing tunes. If you have any questions about the set up and data i was provided by Paul busbey, paramount performance owner, please ask away.
Otherwise, please check out the marketplace for individual part listings! Thanks! Items are selling super fast, and the air filters and fu manifold back exhaust will be no longer available shortly. Thanks all!!
.chris
Just a heads up all, i have significantly discounted these parts even further, THEY HAVE TO GO, THE GIRLFRIEND IS GOING TO KILL ME FOR HAVING THEM TAKE UP ALL THIS SPACE!! Cats already sold, smooth transaction that sent them out to Cali!
Still have Full Switchable Cat Back (with x pipe) Paramount Performance Exhaust System
Upgraded Supercharger Radiator/Intercooler/Charge Cooler
Upper Supercharger Pulley
Lower Supercharger Pulley
Tune
Full Bushings Set (Powerflex aftermarket)\
Full 30mm drop springs set
Jet Fighter exhaust tips for the exhaust system
If you have any questions regarding applicability, fitment, performance etc, please let me know!
From Ian Macfarlane @ #TeamVIEZU I have read the V6 supercharger will only handle 2lb of boost more. Is this true?No, the charger can run a lot more boost than just 2lbs, if the charger was ported and polished it would flow even more air we currently do with the uprated supercharger and crank pulley kit we supply.
The lower crank pully that you offer. It's aluminium, or steel? Is the pully balanced and does it have mass damping?The pulleys are balanced during the manufacturing process. It is an added bonus if you can get the supercharger crank pulley and aux pulley balanced together for 100% peace of mind. However, we have fitted hundreds of our conversion kits for track cars, fast cars, show cars and everything in between cars and have never had a balancing issue from just fitting the new supercharger crank pulley.
Charge cooler. Who is the manufacturer? What are the dimensions/difference form OEM. What cooling difference will it provide over OEM?The charge-cooler is our own product and is manufactured by our engineering company. The charge-cooler is around 25%+ deeper as it cannot be made any wider or taller due to location restrictions. This is inline with how JLR run uprated coolers as standard on the Range Rover supercharged engines. This will not make the supercharger colder, but it will help reduce the rate of increase of the temp in the charger. Given the higher rpm rate of the charger its something that we strongly advice is fitted.
Replacing the air filters. Would a Cold Air Intake be better than just replacing the air filters? What air filters are you using? What is the airflow difference?The air filters are really a throttle response improvement and an audio improvement. On some cars you can hear a little more induction noise. The panel filters will not provide a hp gain but do help the car respond a little sharper.
Top supercharger pulley. How touchy will the throttle be and will this change not overspeed the supercharger?This will not cause the throttle to be too sensitive at all, it will however help provide the mid-range torque and hp delivery the engine desperately wants to have.
I wouldn't bother with the upper pulley on the v6, the percentage in size difference is pretty negligible so doesnt give you a lot more power
unlike the v8 upper pulley.
.chris
@kevo87 This post was from back in 2019 and the last update was 2020. Assuming you may not have seen the dates of the thread. I am sure these parts are long gone, but the good news is, these are mostly still available from other vendors.
