Rattle Can Touch-Up Paint
Old Apr 26, 2024 | 06:37 AM
SassySarah's Avatar
Default Rattle Can Touch-Up Paint
Does anyone know where I might find Fuji White in a rattle can?
Old Apr 26, 2024 | 07:11 AM
RGPV6S's Avatar
https://www.automotivetouchup.com/spray-paint/spray_paint_matched.aspx
https://www.crosslinkpaints.com/PPG-Matched-12-OZ-Touch-Up-Aerosol-Spray-Paint-Can.html
Old Apr 26, 2024 | 07:12 AM
CJSJAG's Avatar
Hope you did not ding your new car!!
Old Apr 26, 2024 | 10:59 AM
SassySarah's Avatar
I did, but it's barely noticeable; the slight ding is near the passenger rear wheel beside the clear protective piece on the rocker panel.. However, my local Jaguar dealer wants $1,800.00+ to fix it.
The affected area is approximately the size of a nickel and the metal is not distorted.
I've tried using a paint pen for both base coat and clear coat but am not happy with the results.
Old Apr 26, 2024 | 11:00 AM
SassySarah's Avatar
Thank you very much. I'll look into those options.
Old Apr 26, 2024 | 11:18 AM
CJSJAG's Avatar
I had a similar very minor scrape by a large Ford F150 that (fortunately) just touched me. Barely anything.
Body shop wanted $1,000+ and wanted to remove body panel to paint.
I purchased a small bottle of guaranteed color match paint with clearcoat from ERA Paints.
My local paint correction guy applied a couple of coats and buffed it out.
No longer detectable. Total cost with paint about $75!!
Hope you can do the same.
https://erapaints.com/product-category/touch-up-paint/
Old Apr 26, 2024 | 11:26 AM
CJSJAG's Avatar
FYI Sarah: Fuji white is not shown on the ERA website but neither is my BRG which they did have.
Old Apr 26, 2024 | 12:24 PM
lizzardo's Avatar
I've been happy with Automotive Touchup's products to match several cars. They'll do everything from touch-up pens to gallons, and have clear coat too.
Old Apr 27, 2024 | 07:14 AM
SassySarah's Avatar
Yes, I called and was told that even though Fuji White was not given as a name for the color (it's listed as Polaris White I believe) it's the same Paint Code and is in fact the right color.
Old Apr 27, 2024 | 07:15 AM
SassySarah's Avatar
Thank you for the info. I'll look into this option as well.
Old Apr 28, 2024 | 05:34 AM
Jag Bass's Avatar
I have use the touchup paint from Touch up direct. You can get it in pen, brush applicator, spray can, and even larger quantities. I got the spray which is a Low VOC water borne pain and also comes with a can of clear coat as well. I got Carpathian Grey which was a perfect match,
https://touchupdirect.com/
Iticip
Oct 30, 2025 04:28 PM
Rodkel
Oct 14, 2023 10:23 AM
WaterDragon
Jul 2, 2021 06:01 PM
Neilpet
Aug 25, 2015 10:10 AM
ukdude
Mar 7, 2015 07:38 AM
