Ravenol oil
Old Nov 5, 2018 | 11:43 AM
magredvet's Avatar
Default Ravenol oil
Anyone used this oil before ? I was thinking of buying this kit. Car no longer has warranty, so not concerned about the dyed Castrol stuff, if this oil is fine
https://www.blauparts.com/jaguar-f-t...t-30l-rwd.html
Old Nov 5, 2018 | 11:48 AM
DJS's Avatar
DJS
No idea about that one, but I used this one, with the recommended oil.
https://www.roverparts.com/Parts/OCK...iABEgLhUvD_BwE
Old Nov 5, 2018 | 12:04 PM
magredvet's Avatar
Ok Thanks DJS, I'll order that kit to be on the safe side!
Old Nov 5, 2018 | 12:24 PM
Don1954's Avatar
You could die of you use that oil.
Old Nov 5, 2018 | 01:19 PM
DJS's Avatar
DJS
I didn't end up using the replacement drain plug that came with the kit, as I used a MityVac. And it's a quart more of oil than you need.
Old Nov 5, 2018 | 03:43 PM
Carbuff2's Avatar
Do you always need to use a replacement drain plug if you loosen it to drain the oil?
Or just if it leaks?
Old Nov 5, 2018 | 04:15 PM
magredvet's Avatar
I have a vacuum pump, so no need to take the drain plug out.
Old Nov 5, 2018 | 04:23 PM
OzXFR's Avatar
The JLR recommendation that if you dump the oil via the drain/sump plug you should fit a new plug is yet another case of overkill.
I have re-used the OEM drain plug several times across the XFS, XFR and F-Type without a single problem. I even have the OEM XFR plug (over eight years old) on the F-Type at the moment, the reason for that is the OEM F-Type plug had a fair bit of silicon sealant on it which was difficult to fully remove so I swapped it out for the perfectly clean XFR plug which I had replaced years ago with a magnetic plug.
They are all the exact same plug and all you need to do is check the thread and the condition and fit of the rubber/plastic sealing ring and if they are perfectly OK you are good to go.
Qvhk
Jan 1, 2018 10:10 AM
jagosaurus
Jan 10, 2013 12:55 PM
93xj6
Jul 27, 2007 08:57 AM
Humy
Jul 19, 2007 12:52 AM
