Rear noise when full throttle (V8 550cv)
Old Jun 6, 2021 | 03:50 AM
Daniel Lòpez Sánchez's Avatar
Default Rear noise when full throttle (V8 550cv)
Hi everyone,in my F-type R 550hp RWD, I'm listening a rear noise when full throttle, I perceive it from under the seat, its only when I go full throttle, not when i go normal or at low speed. recently i changed the gearbox and rear differential oil on Jaguar a few months ago.
Old Jun 6, 2021 | 05:14 AM
scm's Avatar
scm
If you can be a bit more specific on "noise", maybe someone could help. Clunk, creak, screech, whine, etc?
Old Jun 6, 2021 | 06:45 AM
Borbor's Avatar
That rear noise that only occurs in full throttle - it’s called the POLICE
Old Jun 6, 2021 | 08:39 AM
I have the car only a month, making slow and normal driving, even revving the car without fully depressing the pedal I don't hear any unusual noise, but when i fully depress the pedal and make a strong acceleration, I hear like a strong vibration right under the driver seat, I do not know if it is something normal in this model
JAJAJAJAJAJAJAJAJ Maybe... 🤣
Old Jun 6, 2021 | 08:42 AM
scm's Avatar
scm
How many miles? Could it be engne mounts? We've had a couple of members on here that have had failures in that area.
Old Jun 6, 2021 | 08:50 AM
70.000 milles, i change recently the oil of the gearbox and the differential, the strange thing is that it only happens when I do a hard acceleration or I step on the gas pedal fully, the rest of the time in normal driving the gearbox is completely smooth and the car works fine.
Old Jun 6, 2021 | 09:54 AM
scm's Avatar
scm
You could try revving the engine with the hood open and engine cover removed to check for excessive engine movement - simple check to eliminate that.
Old Jun 6, 2021 | 10:15 AM
Im going to try that, but the vibration comes more from the rear-central part of the vehicle.
Old Jun 6, 2021 | 11:23 AM
355rockit's Avatar
I had strange clunk noise under hard acceleration on my '15 R. Turns out it was a failed engine mount. The noise went away after replacement of the engine mount.
Old Jun 6, 2021 | 11:41 AM
Thunder Dump's Avatar
Could be failing universal joint on the drive shaft--especially when on hard launches/wide open throttle.
Old Jun 6, 2021 | 12:24 PM
DJS's Avatar
DJS
Are you sure they used the proper fluids?
Old Jun 6, 2021 | 12:36 PM
I changed the differential oil in Jaguar. I'm also not sure that the problem is the rear differential... the strange thing is that the vibration only occurs when accelerating to full
Old Jun 6, 2021 | 12:59 PM
Diagnostic machine error codes
Old Jun 7, 2021 | 05:16 PM
Therock88's Avatar
No idea what that says (I only speak English, and Italian and French curse words ).
Since you just changed the fluids, I am going to suggest something is out of line, or loose. When you or whomever did it, you may have not re-fastened something properly. Assuming it was not there before you did the work?
I would try that first, before assuming you have bigger problems. Check for loose fasteners, heat shields and plates.
DC
Old Jun 8, 2021 | 01:22 AM
DC
The noise was already there before changing the gearbox oil..
Old Jun 8, 2021 | 02:47 AM
bcbruno's Avatar
I had my diff refurbished (not sure exactly what Jaguar fixed under warranty, listen about bearings, etc but they didn't specify), at beginning also felt some vibration under seat and on back, i assumed was Winter tyres but then a whining started a low speeds. I also asked for all fluids changed (flushed) on gearbox. Is perfect now.
Also, they fixed exhaust piping rubbing on subframe, and it vibrates quite, check that (by your description looks exactly that).
Old Jun 8, 2021 | 03:38 AM
Hi bro! the strange thing is that I only feel that vibration when I perform strong accelerations, the rest of the time the car is docile and quiet and gear changes are smooth even at high speed I do not perceive that vibration, only when i make strong accelerations...
The car have changed the oil of gearbox and differential months ago.
Old Jun 8, 2021 | 03:57 AM
bcbruno's Avatar
Try go under the car and check if the exhaust pipe (my case was the left one) is not too near any reinforcement or chassi, use a crowbar (gently ) to verify.
Old Jun 8, 2021 | 04:00 AM
​​​​​​Thanks bro! I'm going to check it
