Removing a Locking Lognut without the Key
Old Sep 10, 2020 | 03:57 PM
Unhingd's Avatar
Originally Posted by 2004XJ8
I don't think mine is the Mcgard type with the scroll work on top. It is the odd ball socket style.
Post a pic of the lock. Do you have the lock code? The installing dealer may have stuck the code decal in your owner's manual.
Old Sep 10, 2020 | 04:54 PM
2004XJ8's Avatar
These are the locks I have It shows the 4 lugs and the lock/socket to remove the lug. One per each wheel is used.
These are factory. I don't think there is a code for these like the mcgard style. The orange one is mine that I painted and label so the dealer
knows to return it. only marking on it is the letter "A"
Old Oct 17, 2020 | 12:39 PM
axr6's Avatar
Just a quick update on my original post regarding the lost key for the locking lugs. After the Jaguar dealer failed to find a solution for getting a new key or to even remove the locking lugs, I called McGARD. They were extremely helpful, asking for me to take a picture of the lugs, showing the pattern, and email it to them. I did and within a couple of hours they emailed back that the new key was in the mail. Total cost, including shipping; $14.99.
Today, after ONLY 2 days, I received the key and it works/fits perfectly. So, the solution was to go to the locking lug manufacturer, McGARD, directly and forget about the Jaguar dealer.
Old Oct 17, 2020 | 02:38 PM
jaglag's Avatar
Random question, but did you check in the foam holder by the battery in the trunk for the key?
Old Oct 17, 2020 | 03:01 PM
scm's Avatar
scm
He's already told us "There is already a dedicated space for the key in the trunk of my F-type. Molded into the foam, right in front of the large battery. It was just EMPTY when I got the car."
Old Oct 17, 2020 | 03:29 PM
Carbuff2's Avatar
But: Once the OP buys a new wheel lock, he is SURE to find the original one! Under a seat, or tucked in a crevice of the boot somewhere.
Murphy's Law.
That is how I eventually find the tools in my garage, that I only use once every 10 years.
Old Oct 17, 2020 | 03:35 PM
scm's Avatar
scm
But: Surely you'd only use the tools once, not every 10 years, because when you wanted to use it again, you've just bought a replacement for the tool you couldn't find!
Old Oct 17, 2020 | 03:54 PM
  #28
Carbuff2's Avatar
That is usually how it works.
When I pass away, it's gonna be one heck of an estate sale.... Even with stuff that I use enough not to lose, often I have to buy extras of many things.
EXAMPLE: I have 3 or 4 OBDII scanners since my first, 20 years ago. Seems as if every newer car I obtain, I need a more sophisticated scanner.
Lets not talk about all the tools I've bought for different fasteners either. Slotted screws, then Philips, then Powerdrive, then square drive, JIS spec, then Torx, then the special sockets that fit the Tornado wheels. Yep: I need a hangar-sized storage unit nowadays!
Sorry for the rant.
Old Jan 5, 2024 | 02:23 AM
mikefarnham's Avatar
If anyone is having problems with the following lockers:1. The two slotted design 1990s and early 2000s
2. The domed top four slotted type 2000 on
3. The 2020 on approx virtually circular design with a wavy circumference
Please get in touch as I have proven, successful solutions for most scenarios.
Hope this helps.
Mike.
Old Jun 1, 2025 | 11:00 AM
  #30
trumpeter's Avatar
Hope this helps.
Mike.
Thanks so much for sorting me out, Mike
(I lost my dome-type locknut key, 2014 XF)
Old Jun 1, 2025 | 07:29 PM
  #31
randyb's Avatar
Originally Posted by Dwight Frye
Regarding the possibility of losing the lug nut key, I have just taken a utility knife and cut a space for it in the styrofoam that is common in many cars in the trunk area where the jack and other tools are. I don't like the idea of storing it in the glovebox or console.
My cars have always been garaged at night and I seldom go to any sketchy areas where theft is a high probability. But I will never forget one night coming out of a concert in San Diego near the bay and seeing a newer Porsche 911 in the parking lot across the street sitting up on cinder blocks with all 4 wheels missing.
As an FYI, had a rear wheel stolen off my car at a VERY fancy restaurant and expensive area of town, luckily my date noticed it before I drove away. Was a VERY expensive night, as well as a long one.
Old Jun 2, 2025 | 03:41 AM
  #32
trumpeter's Avatar
The thing is, Dwight, I 'lost' my key after forgetting to remove it from the wheelnut! The XFs have a dedicated space for it in the boot, and that's where I always, always used to put it. But on that day it rained just as I was finishing up. I only realised two days later, when I noticed I hadn't put the spare away properly. I thought I was the only twit ever to have done that, but in my searches for a fix I discovered I'm very much not alone!
I don't have any locking nuts on now. My car is old and my alloys are all too scuffed to be valuable enough to warrant the effort involved in stealing them, I hope!
iownme
Feb 24, 2019 05:20 PM
CaptainHam
Apr 1, 2018 12:25 PM
lynnpt2001
Dec 16, 2016 05:48 AM
cruisin
Feb 28, 2015 11:37 AM
engsnayl
Aug 22, 2012 08:32 AM
