Reset after battery disconnected
Old Nov 30, 2014 | 11:41 AM
ldmack3's Avatar
Default Reset after battery disconnected
In the continuing saga of trying to get my charger working properly (separate thread) I had to remove the battery to retrieve some dropped hardware. No problem getting that accomplished and finishing my original objective.
Once completed I began checking everything and resetting as necessary. The door locking was goofy until I cycled it with the remote several times. The windows express close was dead so I reset according to the OM. LH now works as advertised. RH still will not close correctly. I go to the 2nd detent on the switch as normal but the window stops as soon as I let go of the switch. I have reset per the OM several times with no success.
So what next for the window?
Is there anything else besides locks, clock and windows I need to confirm. Radio presets are all fine as are all other settings.
Thanks all
Old Nov 30, 2014 | 01:07 PM
another_geek's Avatar
You probably need to re-program the seat memory and verify the interior lights work when opening the door. Other driver config settings like auto-lock the doors, and dipping the mirrors in reverse may have also been reset.
Old Nov 30, 2014 | 06:28 PM
DJS's Avatar
DJS
Wow, I thought the radio would need a code to reactivate it - thought I saw that in the manual.
Old Dec 1, 2014 | 02:25 PM
F-typical's Avatar
Given the degree on systems and physical integration, I'm guessing that isn't needed...
Old Dec 2, 2014 | 08:50 PM
mshedden's Avatar
Is there a 'Car will not function when radio removed' sticker?
Dagny
Jun 11, 2024 01:06 PM
trosty
26
Dec 18, 2022 06:40 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
DuhCar
Sep 11, 2015 10:58 AM
DEklof
Sep 8, 2015 05:28 PM
