Retrofit design pack diffuser?
Old Jan 5, 2020 | 12:17 PM
glenn b's Avatar
Default Retrofit design pack diffuser?
I see a few V6 design pack diffusers on Ebay. Are they a straight swap? I understand the reverse/ fog lamps are different. But if i find a set will they have the same electrical connector as mine? Anyone done the swap diy? Thanks Glenn.
Old Jan 5, 2020 | 01:13 PM
Unhingd's Avatar
Simple bolt-on. Same connectors.
Old Jan 5, 2020 | 03:33 PM
peppersam740's Avatar
Is that Jag part number T2R8978LML ?
Old Jan 6, 2020 | 02:52 AM
scz4's Avatar
Certainly looks like it. I assume it comes primed and you have it sprayed? Or is there a specific part number for an all gloss black version?
Old Jan 6, 2020 | 03:22 AM
I believe it comes on the F-type 400 only. It has the bottom lip that can be painted the color of the car. Jag. sells it for about 1,000. No body I talked to at Jag knew if the rear fog lights fit into that one.
Old Jan 21, 2020 | 10:02 AM
scz4's Avatar
Did you manage this? Looking to do the same.
Old Jan 21, 2020 | 10:17 AM
Negative as of yet. I have tried to get that valance part number everywhere. I think it's only available in the design package witch comes with other splitters you might not use. Google Jaguar design pack and you should be able to see the package. A lot more money.
Old Jan 21, 2020 | 10:27 AM
scz4's Avatar
Loads on ebay in the UK or Germany. I just picked one up for $150 (no lights) just needs a light rub down and respray in gloss black.
Old Jan 21, 2020 | 10:47 AM
That sounds like the base diffusor. They sell for that here in the U.S. It's the diffusor seen on the Jag F-Type 400sport that we want.
Old Jan 21, 2020 | 12:13 PM
glenn b's Avatar
The diffusers are available 2nd hand on Ebay but i can't find the correct reverse/fog lamps at a sensible price.
Old Jan 21, 2020 | 12:24 PM
scz4's Avatar
No no, definitely the Design diffuser. I didn't buy the entire bumper. As I mentioned, will need a light rub down and respray.
https://www.ebay.co.uk/itm/Jaguar-F-...p2047675.l2557
Old Jan 21, 2020 | 12:29 PM
Yes I SEE .. You got a great deal.
TAEUCK Goo
Dec 12, 2019 04:40 AM
thingon1
Oct 31, 2019 05:20 PM
Jmo
Jun 25, 2019 11:01 AM
helo008
Jan 18, 2018 08:00 PM
OzXFR
Jul 18, 2017 06:40 PM
