Rod Knock?
Old Aug 25, 2023 | 10:01 PM
Justin4u973's Avatar
Default Rod Knock?
Hello everyone I own a
2016 F Type V6S
just hit my 100k mile mark! She’s a real beast!
However this noise has appeared and I am hoping it is not rod knock. This noise disappears when driving only appears during idle.
any clue what it can be???
cars runs perfectly! No issues
https://www.dropbox.com/scl/fi/b76j7ue40y621m2mv04rg/IMG_7739.mov?rlkey=egh93u6v5bo04au792b3uzihn&dl=0
Old Aug 25, 2023 | 10:24 PM
randyb's Avatar
Rod knock would not go away, it would get lighter the lower the rpm's. Give us more info, does it run rough, miss or what??
Only listened to the first video, does not sound like a rod knock but really hard to tell. Sounds more like a sewing machine, which might be a stuck or dropped valve, but need more info.
Old Aug 25, 2023 | 10:42 PM
Default Edited
thanks for the suggestion about more information.. the car runs and drives perfectly. No rough idles or rough driving and smooth rpm’s all around .
Old Aug 26, 2023 | 12:38 AM
OzXFR's Avatar
Doesn't sound like any of the usual culprits I have heard before on the V6 or V8, such as injector tick, SC coupler rattle, SC tensioner rattle, HP fuel pump rattle etc etc.
But it does sound a lot like rod knock to me - deep and regular - unlike a rattle or a tick.
Could also be worn SC bearing(s) I suppose.
Easy enough to check if it's SC coupler or SC bearings or SC tensioner - just take the SC drive belt off and if the noise is still there it isn't one of those.
Old Aug 26, 2023 | 08:19 AM
I’ll give it a try, however if it was a rod knock would I not hear it while driving? Even driving on low rpm’s? The noise fades away the moment I drive off.
Old Aug 26, 2023 | 08:33 AM
I also want to mention that this noise does not appear off a cold start.. appears as soon as car gets revved or run
Old Aug 26, 2023 | 08:43 AM
MajorTom's Avatar
I once had an XF with the same engine which turned out to have a messed up con rod bearing. The noise it made was very similar to this but never went away, just got less obvious while driving. So the sound itself definitely sounds like a rod issue to me, but the other things you mention speak against it. I'd get it checked by a JLR dealer.
Old Aug 26, 2023 | 08:46 AM
do you have any videos on it? Or can you speak more in terms about your issue? And how you had it fixed ?I really hope it’s not a rod issue
Old Aug 26, 2023 | 09:18 AM
MajorTom's Avatar
Sure, I have a couple of videos that I'll try to upload somewhere.
Mine had around 33k miles on it when it appeared, if I recall correctly. It started during a very spirited drive, started with some metal screeching noises from the engine, then just settled to this kind of knock which didn't go away. The car drove just fine and someone less attentive may not even have noticed the knocking. Got it diagnosed by a Jag dealer that concluded that it was a damaged con rod bearing. I got a new engine under warranty.
That AJ126 was a pretty early one, produced some time during 2013 I think. Apparently many of these engines produced up until about mid 2014 had con rod issues because of some manufacturing fault. Seems like there was some bad batch of bearings at some point. Many blew, some F-Types, because of the tight packaging I guess, even went up in flames. Some only developed a knock like mine and got replaced. That said I always thought it's extra risky to buy any Jag or Land Rover with an early AJ126 engine. Anyways, your car seems to be newer so it shouldn't be affected by that particular issue.
Old Aug 26, 2023 | 09:28 AM
oh okay , thanks for that ! Yeah I might have to just take it to a JLR Dealer because this noise is strange and to me.
Old Aug 26, 2023 | 05:29 PM
Doc Oc's Avatar
When you rev in park does the knocking increase in speed with the revs?
Old Aug 26, 2023 | 07:55 PM
no it does not it fades away, or at least from what I can hear the noise decreases
Old Aug 26, 2023 | 11:19 PM
Doc Oc's Avatar
If you spun a bearing the noise would speed up with revs...but it does sound internal to me. Couple things I would suggest would be to go to Blackstone and request a free oil testing kit....draw a bit out and send it to them....it'll give you a good idea if there's excess metal in your oil. If it's a conrod bearing it'll be shedding aluminum, nickel and maybe iron and Blackstone will find it. Another thing you can try is when the engine is up to temp, in park, give it a good quick rev up to about 4500 rpm and quickly let off the gas. You gotta do it quick though, can't slowly run it up and let off....you kinda wanna stab it. A lot of times a bearing will rattle right at the top of the rev as soon as you let off for just a quick second. If you hear that rattle it gives us a good idea what's up. If you could get some audio doing this it would help.
Old Aug 28, 2023 | 03:29 AM
Stuart@VelocityAP's Avatar
Came here to say - send some oil out for testing, you'll know pretty quickly if you've got metal content!
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Old Aug 28, 2023 | 08:52 AM
Jp129's Avatar
You can also take a look at your oil filter. If you've spun a rod bearing, there's a great chance you'll see bearing material in the oil filter.
Old Aug 28, 2023 | 01:39 PM
Unhingd's Avatar
+2 on the oil analysis. $35 at Blackstone should tell the story. But that does sound like a bad rod bearing. A bad SC coupling sounds more like a clicking sound.
JagXtype04
Feb 25, 2017 05:50 AM
kingfishgrapejam
Sep 6, 2016 05:34 AM
dhardison
Dec 14, 2015 01:41 PM
guzzi svt
Apr 15, 2013 06:50 AM
pauliejr
Oct 30, 2007 01:50 PM
