show n go plate
Old Jun 25, 2015 | 01:01 PM
idoc1992's Avatar
Default show n go plate
Just wanted to let those in 2 license plate states know that I had the show n go plate by Altec installed this past weekend and it works perfectly. There is plenty of room under the 'curb warner' although it does require removing about 6 inches of same. The curb detector comes in 3 screw-on pieces so is easy to replace if the plate is no longer needed. Great product, love the ingenuity behind it. Corvettes of Dallas installed it for me (I got the remote controlled version), took about 2 hours but they hadn't done it on a Jaguar before. I added a little soft Velcro to the back of the holder because some of the plastic does touch the front bumper, so don't want any vibration scratches. Wouldn't have worried about it too much but it's a $200 fine in Texas if you get stopped (I was once before in a 370Z).
Also, Hello, new to the forum!
Old Jun 25, 2015 | 01:33 PM
LynxFX's Avatar
And welcome!
Old Jun 25, 2015 | 01:34 PM
Foosh's Avatar
Welcome to the forum.
It's too bad you weren't aware of this solution, which doesn't require carving up your car, and is quite a bit more economical.
http://https://www.jaguarforums.com/...racket-144955/
TwiztOG43's Avatar
Your going to regret that one in a couple months, it will fall apart since the materials used are so cheap. I have used it on my previous car, ended up just running no front plate since I was too lazy to fix it.
You should really look into this one
https://www.jaguarforums.com/forum/f...racket-144955/
Old Jun 25, 2015 | 02:30 PM
buickfunnycar.com's Avatar
LOL...a day late to the party.
Old Jun 25, 2015 | 03:02 PM
idoc1992's Avatar
Hey thanks for all the support! (j/K I can take it). As far as the sto and sho, I wanted something I can do remotely on the spot when my radar goes off. City cops are no problem but wouldn't put it past DPS to stop me. If it falls apart, lesson learned but since I don't plan to activate it very often, I'm not worried.
Old Jun 25, 2015 | 03:21 PM
Foosh's Avatar
My thoughts are I'll always run the front plate when I'm driving the car. Why should I care, I can't see it then, and I sure don't care what other people think. If I don't like looking at it at other times, I'll pull the pin and stow it in 2 seconds.
Old Jun 25, 2015 | 03:40 PM
Originally Posted by Foosh
My thoughts are I'll always run the front plate when I'm driving the car. Why should I care, I can't see it then, and I sure don't care what other people think. If I don't like looking at it at other times, I'll pull the pin and stow it in 2 seconds...
My sediments exactly,I'm headed out tomorrow to the Bay Area for the JAG 60th anniversary bash and I'll be driving with it on the entire time...
Old Jun 25, 2015 | 10:17 PM
355rockit's Avatar
Default plate holder installed
Here is a pic of mine installed...
Attached Thumbnails show n go plate-img_20150625_181042.jpg   show n go plate-img_20150625_181032.jpg
Old Jun 26, 2015 | 12:22 AM
LoneAspen's Avatar
Jag 60th anniversary? What's that event - is there a web site with info?
Thanks!
Old Jun 26, 2015 | 09:38 AM
Thanks!
Jaguar Cars JCNA, Jaguar Associates Group 60th Program and Maps
May already be sold out,the host hotel is The Doubletree by Hilton in Pleasanton and the cocktail reception is tonight at the Blackhawk Museum in Danville...you might also try treasurer Phil Endliss @ (650) 854-4445
www.jags.org
Old Jun 28, 2015 | 08:53 AM
TR64ever's Avatar
I ordered the Altec Show n go frame before my car was delivered, when I got it I set up the wiring and waited for delivery. Then I realized that if I installed it I wouldn't even make it out of my driveway before I scraped it off. Love the idea of cutting some of the "curb scraper" out but don't think this will last in the real world.
I just ordered the Stow n show frame from Mike, I'll use that. I'll also refer my dealer to Mike, my dealer's solution was to tell me to carry a PBA card and have a good story ready (interference with parking sensors and cooling was my story).
My dream would be an Altec show n go that comes out of the lower air splitter -- the splitter would need to be cut, and small "lips" fashioned so it was flat and tight when the plate was retracted. But for now, I think Mike's solution is the best...
H20boy
Dec 24, 2024 03:23 PM
user 652867429824
Oct 28, 2015 10:18 AM
Lawrence
XJ40 ( XJ81 )
Sep 18, 2015 02:03 AM
Jaguar Forums Editor
Jaguar Press release
Sep 17, 2015 11:18 AM
Ipc838
Sep 13, 2015 03:27 PM
