Slight thump when pressing and releasing gas pedal
Old Aug 18, 2022 | 08:52 AM
tepid's Avatar
Default Slight thump when pressing and releasing gas pedal
As the title says, I've noticed a dull "thunk" probably half the times I press on the gas pedal. This also happens at the about the same frequency when I release it, while decelerating. I can only describe it as a feeling more than an actual sound, as if it were catching a gear, and only happens while I am driving.
Otherwise, it runs fantastically smooth, so I'm hoping that this is not too big of an issue. I'm also seeing my local JLR for an unrelated service (new brake pads) in a couple of weeks and I plan on bringing it up to the mechanic then. For reference, my F-Type R has 23300 miles on the odometer.
Cheers!
Old Aug 18, 2022 | 09:24 AM
scm's Avatar
scm
Any clue as where you think the thunk is coming from? We could do with more information!
Old Aug 18, 2022 | 09:31 AM
tepid's Avatar
My apologies, I should have specified! It feels like it's coming from the front/engine.
Old Aug 18, 2022 | 01:10 PM
tepid's Avatar
I can also feel the "thunk" at my feet.
Old Aug 18, 2022 | 01:13 PM
kb58's Avatar
I assume you only feel/hear this with the engine running. If true, I suspect that something, probably part of the exhaust, is contacting the chassis as the engine rotates due to torque, producing the "thump." I suggest getting under the car and looking for contact witness marks.
Old Aug 18, 2022 | 01:24 PM
pegleggreg's Avatar
Motor mount?
Old Aug 18, 2022 | 01:32 PM
kb58's Avatar
Yes, could be that as well. I had that problem myself after I bought my car, though in my case, there was no thump, only suspicious marks on both the engine cover and hood... sure enough, bad left side mount.
Old Aug 18, 2022 | 03:08 PM
tepid's Avatar
Only occurs while driving—most notably in the lower gears. When idle, I don't hear/feel a thing, even when revving (aside from the normal snap-crackle-pop).
Old Aug 18, 2022 | 03:12 PM
tepid's Avatar
Originally Posted by pegleggreg
Motor mount?
Upon further digging, that seems like it could be a possibility. Is there a surefire way to know for sure before I head to the mechanic?
Old Aug 18, 2022 | 04:58 PM
kb58's Avatar
Open the hood, start the engine, hold the brakes on, put it in Drive, and apply the gas slightly (to apply torque to the engine). If there's a failed left side mount, the engine will rise up. Not sure how to test the right-side mount.
Old Aug 19, 2022 | 04:42 PM
UKSteve's Avatar
same procedure you just said for the left mount but put the car in reverse
Old Aug 19, 2022 | 05:09 PM
kb58's Avatar
I actually said that but erased it because the engine is turning the same direction... thinking about it again though, I think you're correct.
Pisara
Aug 31, 2021 06:10 AM
Portlander
May 31, 2021 04:02 PM
toronadomike
Oct 16, 2013 04:53 AM
shaune
Feb 14, 2013 10:06 AM
whoisjongalt
XJ40 ( XJ81 )
Oct 7, 2008 09:12 PM
