Soft top seals rubber care
Old Mar 13, 2016 | 07:58 AM
SinF's Avatar
Default Soft top seals rubber care
I had been driving convertibles for a very long time, my first one was right after I graduated. They all seem to suffer from the same rubber seal related problems. While over years, and with double seals, convertibles got a lot better, rubber compounds did not seem to improve that much.
So I learned you have to do yearly seal cleaning and conditioning if you want it to keep water and noise out.
For years, I used Gummi Pfledge, but recently switched to Wurth Rubber Care, but I would like to hear your recommendations.
Old Mar 13, 2016 | 04:26 PM
uncheel's Avatar
I've been using Wurth for some time on the Jag's & Targa and have been pleased. I replaced the front seal on the e-Type many years ago, before giving it any special treatment, and it's held up ever since.
Old Mar 19, 2016 | 03:38 PM
slojotaa's Avatar
I just noticed on my F type that it was breaking down already. Have to take it in then continue to treat it as you described. I never knew this frankly!
Old Mar 19, 2016 | 04:06 PM
SinF's Avatar
Could you take pictures of your issue so the rest of us know where to spend extra time treating?
Old Mar 23, 2016 | 01:11 PM
Uncle Fishbits's Avatar
Would love to see this. I don't have a garage, and with the last bits of rain, I've been very impressed with the run off points on the car itself, but there is pooling at the seals of the body and vert. Would love to know if there is any care or maintenance to consider.... or any comments on older F-Types and whether there is penetration danger, etc.
I'm actually still unsure of what you guys are doing with this rubber stuff that is mentioned? Just applying it?
Old Mar 23, 2016 | 01:32 PM
SinF's Avatar
First, take damp rag and wipe the seals. Then take dry clean rag and dry them off. Then take the spray and shop paper towel and spray and wipe the chemical on seals, taking care not to spray other things, as it may stain fabrics.
Old Mar 23, 2016 | 01:51 PM
DJS's Avatar
DJS
I've never tried any of these products, but I like the stick applicator of the Gummi vs. the spray application of the Wurth.
Neither are currently available on Amazon, but 303 has a rubber protector with a sponge applicator that looks reasonable. I use their waterproofing on the convertible roof.
Amazon.com: 303 (30324) Rubber Seal Protectant - 3.4 fl. oz.: Automotive Amazon.com: 303 (30324) Rubber Seal Protectant - 3.4 fl. oz.: Automotive
Old Mar 24, 2016 | 06:39 PM
A seemingly concise, simple, rational conclusion. Thank you much!
slojotaa
Feb 4, 2025 08:35 AM
MK2
May 12, 2016 04:44 PM
Philly Single
Mar 25, 2016 10:49 PM
harvest14
Mar 24, 2016 09:13 AM
adenshillito
Mar 19, 2016 03:04 AM
