Squeakly noise when driving slowly (brake pads?)
I have a bit over 14,000 miles on my F type and have noticed that when I am driving between 8 and 14 mph there is a lite squeak sound coming from what seems to be the front drivers side wheel. Could this be an accumulation of brake dust and can I remedy it by a few acceleration with hard braking?
I am having a set of Conti extreme DW put on later this week, so I can mention it to the mechanics.
I have a similar issue and believe it to be brake dust, I have occasional squeaks with low speed braking. It pretty much always goes away after cleaning and yes it is generally improved with a reasonably hard stop or two. Brakes work great and the squeaks don't bother me too much. A switch to low-dust pads would probably help.
I've never been able to understand the need for dozens (if not more) varieties of (size/shape of) brake pads. You would think the requirement could be whittled down to a handful of standard sizes.
Same goes for oil filters.
many times the issue is a miscalibration of the parking brake after a brake job. Battery has to be reset.
https://static.nhtsa.gov/odi/tsbs/20...64315-6903.pdf
Yes I am aware. Many people Google car problem symptoms and reach these unresolved threads far after the threads have been posted and closed. So I thought I'd add to it, just in case someone is experiencing similar issues. I think its better than starting a new thread.
innzane
Sep 2, 2015 10:08 AM
