Sticky Orange Paddles --- any way to restore?
Old Jun 26, 2017 | 09:28 PM
pjr300's Avatar
Default Sticky Orange Paddles --- any way to restore?
I've had my 2014 V8 S (Firesand, Black Pack, etc) for about 60 days and every day is more fun. My normal DD (2015 Caddy ATS) sits in the garage unless it's projected to rain or I'm going to be at the bowling center (need the trunk space). Such fun!
One issue with the car, which I expected and now have experienced upon its arrival, is the sticky paddle shifters. The car spent its life down south, which promoted the issue even further I am sure.
My question --- has anyone tried just removing the coating with something like Goo Gone? I was thinking of trying that, and then recovering them with wax or sealant, instead of going thru the trouble of a warranty claim.
Old Jun 27, 2017 | 05:38 AM
Unhingd's Avatar
Regardless what you do, be certain to remove the paddles before you use any solvents on them. You might consider coating them with Plastidip. There are some "Luxury Metal" colors that might look good: https://plastidip.com/our-products/plasti-dip/
Old Jun 27, 2017 | 05:47 PM
Dwelter's Avatar
had the same issue with my car. removed the paddles and cleaned aggressively with denatured alcohol. they look perfect. the alcohol removed the sticky residue without damaging the color or integrity. learned this technique on my jeep wrangler dash.
Old Jul 2, 2017 | 01:58 AM
AnD3rew's Avatar
On this subject, my paddles are ok, but my start button is sticky and scratched. Anyone replaced that?
Old Jul 2, 2017 | 03:40 AM
OzXFR's Avatar
Yep, several have done it, although for the life of me I can't find a thread or post on it!
I even remember a fairly recent post where a FM said he removed the OEM start button without having to remove the surrounding trim, by simply wrapping a thin flexible piece of plastic around it and pulling it up and out.
Old Jul 2, 2017 | 07:00 PM
pjr300's Avatar
this worked perfectly! Got a towel and some rubbing alcohol, removed the paddles (one hex nut) and the goo came up with some elbow grease... look Great! One note of caution: removing the paddles only disconnects them from the column, as the wires are still intact. So, clean with care and don't pull on anything!
thanks all... happy motoring!
Old Aug 29, 2017 | 05:45 PM
salukutinaveen's Avatar
Did you try this on the other buttons as well ? Why do have to remove the paddle shifters.. would it damage other parts ..
Any help is appreciated !
Thank you
Old Aug 29, 2017 | 10:25 PM
pjr300's Avatar
Good questions!
I only tried it on the orange paddles, since that was the only "sticky issue" that I needed to address.
And I removed them because access was difficult.... if I wanted to be thorough, it was a challenge to get into the tight spaces. I possibly could have accomplished the cleaning if I used a small instrument or a Q-Tip, but possibly not.
