Suspension broken by springs
Old Apr 14, 2019 | 08:03 AM
T-Mack's Avatar
Default Suspension broken by springs
Hi all. I do not know what the problem is but the front axle of my F-type R Coupe stays 2 cms high instead of 2 cms lower when installing Eibach springs. After removing and putting the springs several times, the right front suspension has broken. Has it happened to someone else?
The cost is 800€ but the worst part is that Eibach does not know why my car does not go down on the front axle!
Old Apr 14, 2019 | 09:33 AM
Chawumba's Avatar
wtf? Maybe if you can provide pictures of what has broken may make it easier for us to offer suggestions. Nothing comes to mind from what you have described so far.
Old Apr 14, 2019 | 10:06 AM
T-Mack's Avatar
[CITA = Chawumba; 2055049] wtf? Tal vez si puede proporcionar imágenes de lo que se ha roto puede hacernos más fácil ofrecer sugerencias. Nada viene a la mente de lo que ha descrito hasta ahora. [/ QUOTE]
There is nothing physically broken. Variable cushioning/suspension offers crazy values. The car is going well but failure of "dynamic driving modes" appears. I can not select any mode.
Old Apr 14, 2019 | 10:16 AM
Tork Monster's Avatar
The shop that installed my VAP springs damaged a strut when removing it and I had this same warning until the strut was replaced. The car rode hard and bouncy during that time too.
The way I understand it, they used a power tool to remove the strut and it spun the strut shaft, damaging the internals?
He said they were too aggressive taking things apart...
The car defaulted to some Extra Hard setting that was pretty nasty, I must say.
Old Apr 14, 2019 | 10:31 AM
T-Mack's Avatar
The truth is that I do not know what happened. I thought it would be a sensor thing but it was the strut. Something happens with my front axle or with Eibach because I have mounted 2 sets of springs and they have been high. So I have mounted and disassembled 4 times until the strut has broken ...
By the way, did you change the 2 struts?
Old Apr 14, 2019 | 10:48 AM
I believe the shop only replaced the one strut they damaged.
The front springs are shorter on the AWD model; if your car is AWD, is it possible they sent you RWD front springs?
Old Apr 14, 2019 | 11:27 AM
T-Mack's Avatar
[QUOTE = Tork Monster; 2055086] Creo que la tienda solo reemplazó el puntal que dañaron.
Los resortes delanteros son más cortos en el modelo AWD; Si su automóvil es AWD, ¿es posible que le envíen resortes delanteros RWD? [/ QUOTE]
El mío es RWD...
Old Apr 14, 2019 | 02:09 PM
Unhingd's Avatar
If you have AWD, the springs might be for the RWD.
Old Apr 14, 2019 | 02:32 PM
T-Mack's Avatar
[QUOTE = Unhingd; 2055151] Si tiene AWD, los resortes pueden ser para el RWD. [/ QUOTE]
Tengo RWD pero tal vez necesito resortes AWD ...
Old Apr 14, 2019 | 02:41 PM
Unhingd's Avatar
Unlikely. I don’t think that’s the solution.
Old Apr 15, 2019 | 01:34 PM
T-Mack's Avatar
One thing is for sure, it seems that I was a bit silly not blaming the workshop ...
Alfredo209
Oct 18, 2012 10:56 AM
Mendo XK
Jun 25, 2012 02:51 PM
MLRocafella85
Nov 19, 2010 09:51 AM
scottatl
Jun 12, 2010 11:04 PM
