TPMS
Old Dec 7, 2018 | 09:15 AM
  #61
Luke Schmidt's Avatar
Unfortunately, the saga continues for my 2016 F-Type (Vin K27000). The original 433MHz sensors that I ordered did not work. But after reading the recent posts in the thread, I was pleased to discover that I had, in fact, ordered the 433 low pressure sensors instead of the 433 high pressure sensors. I quickly ordered the right ones, and was confident that swapping them out would be the solution. Well, even after swapping them out with the OEM 433 high pressure sensors, the TPMS fault error remained.
At this point, I reluctantly decided the only thing left to do was to take it to the dealer and have them manually program the sensor ID #'s into the car's ECU (which I took pictures of before having them installed at the local tire shop). The dealer told me it was a success, and after $145 for 1 hour of labor, I was on my way. The error was gone, but when I went to check the individual tire psi, they all showed "0", whether the car was on or off. About 10 miles later, the dreaded TPMS system fault error was back.
Now I'm really at a loss. If even the dealer can't get these things working, what other options do I have? I'm half tempted to take the tires off my original wheels and confirm without a shadow of a doubt that they say 433MHz on the sensor itself. If it turns out I've actually needed 315Mhz this whole time...
Old Dec 7, 2018 | 09:19 AM
  #62
docman's Avatar
Originally Posted by docman
I just went out to run an errand and to my delight, the TPMS fault indicators have finally gone out.
It only took 3 weeks and 700 miles - Crazy!
A couple days later, my fault indicator came back. I've got an appt. at my dealership on Monday.
Old Jul 19, 2019 | 10:16 AM
  #63
Jaggyx's Avatar
Getting new wheels and not exactly thrilled after reading this thread...
TireRack is selling these 433Mhz sensors for my 2016 F-Type VIN K29XXX. Can I assume these will work?
https://www.tirerack.com/tpms/detail...y=4&S200_Qty=4
Edit: Also these https://www.ebay.com/itm/OEM-Land-Ro...75.c1#viTabs_0
Edit 2: The Ebay TPMS Sensors clearly state what the gentleman at VelocityAP mentions above: GX63 – 1A159 – AA. In other words, these are 433Mhz high speed sensors which should be just what I'm looking for.
Edit 3: Went with these. Killer deal. https://www.ebay.com/itm/1-NEW-OEM-L...72.m2749.l2649
Old Aug 22, 2019 | 07:58 AM
  #64
Fabco's Avatar
I can confirm that the schrader dual band tpms sensors sold by discount tire ($60) worked great in my ftype. They broadcast both 315mhz and 433mhz and thus should work on all year models. Certainly, they worked on my 433mhz car.
Also available at amazon for less but the extra money at discount tire covers a 7 year warranty and installation.
Amazon Amazon
Old Aug 22, 2019 | 11:38 AM
  #65
Jaggyx's Avatar
https://www.amazon.com/Schrader-3350...gateway&sr=8-6
Good to know. And for reference, while I did buy the OE sensors from the eBay link above, they do not seem to "awake" themselves. The seller mentioned that the sensors do need to be woken up. I still haven't done this unfortunately.
Old Aug 22, 2019 | 02:41 PM
  #66
Fabco's Avatar
Correction that was 6 years warranty not 7.
As far as amazon part needing to be awakened, the tire store ons seem ready to go or have been preprogrammed by tire store. I didn’t notice them hooking up their tpms tool but they certainly had one to check my original tire frequency and they can wake them up for you. Does programming them to a particular make and model require the tpms to be out of the tire and inserted into the programmer? Good question but I don’t think so.
Technically, if I understand correctly, waking them up is using one of these tpms programing tools to take them out of storage mode which saves the battery, and putting them into park mode to match what a parked car is searching for. Many tire shops have these tools to do this for you. It can be done on the car without removal I believe.
The actual discount tire part number was: schrader 33520 tq12 t10. Slightly different than the amazon part, fyi. Not sure if any substantive difference, though.
Old Feb 11, 2022 | 10:49 AM
  #67
clubairth1's Avatar
Community Influencer
That TPMS mentions it's ONLY rated for 130 mph?? I have never seen a speed rating on a TPMS?
Is there a speed rating? What would happen if you exceeded that speed?
I have raced my XJR to 180 mph with no problems yet.
Old Feb 13, 2022 | 01:26 PM
  #68
jcb-memphis's Avatar
Have a set of $41.xx ebay sensors on my car and the car picked them up right away, no issues. I did nothing special....bolted the new wheels right up in my garage (had the tires mounted at a tires shop I trust...).
In fact, read one tire 3 psi low so I addressed it.
The keywords I used in the add were US (for United States) and 433 and somewhere about Jaguar/Land Rover.
Free shipping. Came in about a week. FYI only.
Selling store was "beautycom" - have nothing to do with them. Note, I have a whole 2 weeks of use on them so far so caveat emptor. At less than 11 dollars each shipped, I could not resist. The looked and felt exactly the same as the OEM ones so talk about possible profit item....
Old Apr 10, 2022 | 09:28 PM
  #69
HermanWiegman's Avatar
Ugh. I have a 2017 Ftype (VIN K44168)
I purchased a new set of summer/track rims, tires, and dual mode 315/433MHz TPMS sensors and now I have the TPMS fault.
Oh well... serves me right to purchase parts before reading every Jaguar Forums thread.
I will try the following:
0) check which part number TPMS was installed in the track tires
1) go back to tire store (no Jag dealer in 150 miles of home) and have them "wake up" the installed TPMS sensors
2) perhaps do a battery disconnect for 30 seconds.
3) do the 1 hour Park/Drive/Park sequence.
4) cross my fingers..
Old Apr 10, 2022 | 09:34 PM
  #70
I have the following in my car. 2016. These are the "newer" frequency. No issues. FYI only. I have NOTHING to do with the vendor and many other similar items may be out there that are just as good.
https://www.ebay.com/itm/143864157557
Good luck. All I am saying here is I bought these and installed them in my car and they've been functioning properly.
Old Apr 21, 2022 | 07:31 PM
  #71
Update: I purchased the Autel TS508 TPMS diagnostic tool, and it is very good.
I plan on using it every time I swap between "street" and "track" tires, and it can be used at the track to quickly read all tire pressures and temperatures in just a few seconds!
I found that my 2017 F-Type VIN K44168 car has the "old" 315MHz frequency system.
But it was interesting to see that there are three different 433 MHz communication formats which cover early/mid/late model F-Types. See picture below.
(Note: the TS508 has a frequency identification menu where it asks you to press buttons on your key fob, so the TPMS sensors uses the same frequency as the key fob)
The auto relearn process given for my 2017 F-Type in the Autel tool is this:
0) presumably start with "activating" the new sensors, or "programming" them if they did not come with a default address in memory.
1) Park car for 20 minutes (so the TPMS sensors and the car's Body Module can listen to each other?)
2) Drive car for > 10 minutes at speeds between 16-64 mph (sounds like a one way ticket on the highway)
3) Warning light on dash should extinguish
The tool also has menus to "copy" sensor addresses in various way.. and "write" to the car's Body Module, but none seem to apply to my 2017 Jaguar F-Type.
Before I finalize my TPMS reset process, I have to first recharge the battery which drains after I use my OBD reader (which doesn't terminate communications correctly)
I need to remember to reset the battery after every OBD use! or I need to get a new reader.
Autel TS508 reading the frequency from the key fob.
Autel TS508 listing 4 different communication options for Jaguar F-Types.
Old Apr 27, 2022 | 07:46 PM
  #72
Ugh.. my saga continues.
Summary: My OEM wheels/tires/TPMS work fine, my track wheels/tires/TPMS do not (due to the wrong TPMS senders)
Apparently the Key Fob and the TPMS may be on the same frequency, or not.
My Autel TS508 tool has a means to identify the frequency of the key fob to help the technician identify which tire pressure sensors are on the car.
Well my 2017 F-Type has a 315 MHz key fob, and 433 MHz TMPS sensors. Go figure.
And the "dual mode" 315/433 MHz TPMS sensors that I cleverly purchased for my track wheels/tires were just plane-Jane 315 MHz units... thanks eBay.
So I am off to find some 433 MHz units with the high pressure rating.
The Autel TS508 tool reported out a recommended part number for my 2017-2021 Jag F-type:
OEM = Continental 433MHz
part number: GX 631 A 159 AA (which many of you will recognize from previous posts)
other number: S1 800 520 76A (not sure why the tool published this, but I wrote it down)
high pressure? C2D47173 (this comes from other forum posts where the OEM sensor was described)
In the mean time, the Autel TS508 tool was able to read the pressure and temperatures of my 315Mhz track tires at an SCCA-NER AutoX event.
It was easy for me to walk around the car and "scan" each tire. Made for easy monitoring and adjustments.
Old Apr 27, 2024 | 10:24 AM
  #73
santacruz11's Avatar
guys thanks for all the info , but i did not change any parts or wheels just had a dead battery, once i charged the battery windows only went 1/2 way up and tire alarm appeared . about 10 ,miles and windows where restored but two weeks later (100 miles) the tire alarm is still up . thanks in advance
Old Feb 3, 2026 | 07:48 AM
  #74
dario_ldz's Avatar
Hello, I bought a 2016 F-type and I cannot get rid of the TMPS sensor error. I went to a nearby tire shop, the diagnostician checked all the sensors, their frequency was 433 mHz, and each wheel was read correctly. After connecting the device that read the signal from the sensors to the car, an error appears and they cannot be programmed. My Vin number is: SAJWJ6BV9G8K22794, please tell me where I can look for a solution to the problem.
Should I buy sensors with a different frequency of 315 mHz?
I haven't had the car since new, I don't know what the correct ones should be, the car came with 433 mHz sensors, but they don't work, an error keeps popping up on the dashboard.
Thank you in advance for your help.
Old Feb 3, 2026 | 08:01 AM
  #75
Tuning@VelocityAP's Avatar
Unfortunately, nobody can help until the issue is diagnosed.
TPMS light is on > Codes are stored in the TPMS module informing why this light is on > find out these codes, and you’ll know what actually needs to be done versus tossing parts at the car and hoping it fixes your issue.
Think of it like an Engine Light, you can change the spark plugs and cross your fingers or read the codes and diagnose what the ecu is flagging as the concern.
__________________
________________
Christopher Edgett
Technical Director
Velocity Automotive Performance Limited
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
Office Tel: (250) 485-5126
www.VelocityAP.com
Tuning@VelocityAP.com
Old Feb 3, 2026 | 08:30 AM
  #76
putinbaytr3's Avatar
I bought 4 Jaguar wheels from a private seller without TPMS valve stems for my MY2020. I bought the valve stems from the tire dealer (Discount Tire in the US). The car did not automatically learn and I had to take it back to the tire dealer for coding. They brought out a handheld scanner which was able to read the information from each individual valve stem without dismounting the tires and do the proper coding.
Old Feb 3, 2026 | 09:11 AM
  #77
scott@VelocityAP's Avatar
As Chris already stated, something is off. I have the same model year F-Type as you. When I went to replace my tires recently, I went ahead and replaced the TPMS at the same time. They were still good, but I knew it was only a matter of time before the batteries died. Here is a link to the one's I purchased. Make note of the part number as it matched to the OEM sensors at a fraction of the price. 433mhz is correct.
Amazon Amazon
With that said, there is a TPMS learn procedure that is required to get the car to identify and program these. Granted as Chris mentioned, if there is another ongoing issue (I have seen many times the TPMS module go bad (sending/receiving unit inside the car) that has nothing to do with the sensors themselves. If you can get access to a good scan tool with TPMS capabilities, you will be able to better diagnose this. Autel makes a great product (what I use).
__________________
Scott Rudowitz
Business Development Manager
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: scott@velocityap.com
www.velocityap.com
Old Feb 3, 2026 | 09:35 AM
  #78
I have had various issues with the JLR TPMS system in my F-Type.
Some are intermittent, some are consistent.
I did install "generic" "dual frequency" senders in my summer wheels, and that didn't work at all.
Scott pointed to the correct Style. GX631A159AA which now works well for both my summer and all-season wheel sets.
Now I only get intermittent TPMS faults or warnings on the track as the tires reach peak temperatures of 70*C, or if the tires are allowed to sink below 25 psi.
Old Feb 3, 2026 | 09:54 AM
  #79
Valerie Stabenow's Avatar
Default Life expectancy of TPMS?
Thank you for posting the correct item and where to buy them. I have a 2017 v-6 Premium, from the TOPIX build sheet I see that it was built in early 2016. It has about 43,000 miles on it. What would be the expected life of these? I have done two complete tire changes in my ownership, no indication from my JLR tech or the car that anything was/is amiss.
Is it advisable to buy these and shelf them until needed?
Old Feb 3, 2026 | 09:56 AM
  #80
We have seen TPMS sensors last 10 years and then some 6 years. The lifespan is normally the battery life, which can vary by environment and usage. Estimated on most vehicles between 6-8 years.
__________________
Scott Rudowitz
O: (1)250-485-5126
www.velocityap.com
