Trunk Will Not Open
Old Oct 15, 2020 | 04:54 AM
Katie Amis Gill's Avatar
Default Trunk Will Not Open
Hello.. I have a Jaguar F-Type R and I can not get the trunk open. I have tried with both fobs and the manual release inside the car. I can hear it trying to release but it will not open when I press the soft buttons underneath to unlatch it. Has anyone ever experienced this problem? Any suggestions?
Old Oct 15, 2020 | 05:10 AM
scm's Avatar
scm
Is it opening at all? I had that when the cargo cover slipped off its pegs and jammed against the door. I managed to force it open but it broke the cords of the cover so the whole lot had to be replaced. Fortunately under warranty!
Old Oct 15, 2020 | 07:31 AM
JacksonvilleJag's Avatar
Can you try pushing down on the trunk lid itself while you push the release button? The jam pegs may be set a little too high.
Old Oct 15, 2020 | 08:34 AM
We tried pushing down on it and pushing the release key and nothing is happening.
Old Oct 15, 2020 | 10:54 AM
Rondog's Avatar
After you hear the trunk unlocking, pull UP on the trunk lid. Some people think the trunk automatically lifts up on its own when the button is pushed. ( Don't ask me how I know!)
Old Oct 15, 2020 | 11:03 AM
scm's Avatar
scm
Mine lifts when it releases. Not very far, but it definitely lifts a bit. I don't have the automatical trunk feature.
Old Oct 15, 2020 | 11:55 AM
malbec's Avatar
Coupé or Vert?
Old Oct 15, 2020 | 03:30 PM
fuzzysquid's Avatar
Are you in valet mode? This prevents the trunk from being opened.
I had this happen when I first picked up my car and immediately went to the hotel. I mistakenly thought valet mode put a cap on revs. All it does is lock the trunk so it can’t be opened without your pin.
Old Oct 15, 2020 | 06:03 PM
How do I know if it’s on valet mode?
Old Oct 15, 2020 | 06:20 PM
OzXFR's Avatar
Per page 61 of my Owner's Handbook:
"SELECTING VALET MODE
Valet mode allows the vehicle to be unlocked
by a parking attendant, without giving access
to the Luggage compartment and glove box.
Valet mode also prevents operation of the Touch
screen, to prevent access to telephone numbers
or navigation addresses.
1. From the Home menu, select Valet.
2. Enter a 4 digit Personal Identification
Number (PIN) (personally chosen). On
completion, touch the Ok soft key. Enter the
PIN again to confirm.
3. If you wish to cancel the PIN, select Delete.
If the PIN is cancelled, or incorrectly
entered, you will be prompted to enter the
PIN again.
4. Valet mode activated is displayed to
indicate that the PIN has been accepted.
The Luggage compartment and glove box are
now securely locked in Valet mode and the Valet
mode On screen is displayed.
Remove and retain the emergency key before
giving the Smart key to an attendant.
DESELECTING VALET MODE
1. When you re-enter the vehicle, select Valet.
2. Enter your four digit PIN and touch the Ok
button.
Valet mode deactivated is displayed to indicate
that your PIN has been accepted.
• The Luggage compartment will return to
the previously set security requirement.
• The Touch screen will be enabled.
Note: If the PIN is forgotten, Valet mode can
only be deactivated by your Dealer/Authorised
Repairer."
It may not work exactly the same on your car, mine is a MY2015.
I have read somewhere that the default Valet Mode PIN is usually either 1111 or 1234.
Old Oct 15, 2020 | 09:30 PM
Unhingd's Avatar
As Rondog suggested, press the release button and try lifting the hatch manually. If it starts to open, raise it manually to the full open position. That should reset the system if it lost its programming.
Old Oct 15, 2020 | 10:20 PM
yes we tried lifting up manually while pressing the release button and it won’t do anything. You can just hear it releasing and nothing...
Old Oct 15, 2020 | 10:51 PM
PIN again.
button.
Repairer."
We tried this and the valet was not activated. Mine is also a 2015!
Old Oct 15, 2020 | 11:25 PM
OzXFR's Avatar
Seems like you have no choice but to bite the bullet and take it to a JLR dealership!
wmlaven
Mar 4, 2020 10:29 AM
anthem
Aug 31, 2015 02:01 PM
WVUBoss89
Nov 18, 2013 11:23 PM
robo5555
Aug 13, 2011 07:37 PM
andemat2
Nov 7, 2009 02:47 PM
