upper oil pan gasket?
Old Mar 21, 2022 | 09:31 AM
iownme's Avatar
Default upper oil pan gasket?
after losing the lower oil pan and a chunk out of the upper oil pan i am replacing them.
is there an upper gasket and a lower gasket for these pans?
Old Mar 21, 2022 | 09:59 AM
Therock88's Avatar
Looks like you have an XF. Did you mean to post in the F-Type forum section?
DC
Old Mar 21, 2022 | 04:07 PM
iownme's Avatar
DC
yes, i have an f type and x type and an xf.
my question is about the f type which is a moot point as its the same motor in an xf, so i'll post there if no one here knows.
edit: just realised the xf details had been put into my sig, i just updated that, sorry for the confusion
Old Mar 21, 2022 | 04:22 PM
RGPV6S's Avatar
Looked at several OEM parts sites and saw you can buy an upper and low oil pan separately or both together. For the life of me could not find the corresponding gaskets. I would imagine they are needed unless they are integral to the parts. Call a dealer and inquire.
Old Mar 21, 2022 | 09:32 PM
lizzardo's Avatar
I haven't looked up the parts or checked diagrams, but would not be surprised if there is no gasket and that an anaerobic sealant is called for, e.g. Loxseal.
Old Mar 22, 2022 | 12:24 PM
RGPV6S's Avatar
Never came across an engine without an oil pan gasket (either lower or upper). Learn something new every day.
Old Mar 22, 2022 | 12:30 PM
lizzardo's Avatar
As noted, I didn't look anything up. I haven't seen it on a car yet and if the pan is stamped steel it'd surely need a gasket, but on motorcycles the machined cast aluminum faces seem to be getting sealer instead.
Old Mar 22, 2022 | 12:33 PM
RGPV6S's Avatar
Just checked the repair manual (should have done that first). Apparently there is no gasket used only Loctite 5901G (RTV).
Old Mar 22, 2022 | 03:07 PM
iownme's Avatar
thanks gents, just goes to prove we're never too old to learn something new
i purchased a used upper and lower still connected to each other for under $100 shipped!
fastscot
Jul 17, 2013 12:25 PM
FloriVol
Oct 23, 2011 01:36 PM
Michigan
General Tech Help
Mar 12, 2008 08:12 PM
