Wheel calibration without dealer?
Old Apr 26, 2019 | 08:27 PM
mwinner's Avatar
Default Wheel calibration without dealer?
I am “finally” upgrading from 19” to 20” wheels. Does anyone know what the method is for calibration of the speedo, and computer?
I am upgrading from 245/40/19 and 275/35/19 to
255/35/20 and 295/30/20 front and rear respectively.
Old Apr 26, 2019 | 08:40 PM
OzXFR's Avatar
No calibration required as there is very little difference in tyre diameter between the two sets both front and back.
Old Apr 26, 2019 | 09:16 PM
mwinner's Avatar
Fantastic! Thank you for the info, much appreciated!
Old Apr 27, 2019 | 06:42 AM
Carbuff2's Avatar
Don't confuse speedo calibration with TPMS calibration (if equipped).
Are you using new sensors or moving the ones from your OEM wheels?
Old Apr 27, 2019 | 10:17 AM
mwinner's Avatar
I will be reusing the existing sensors, and was planning on putting them back onto the same corners. Is that necessary?
Old Apr 27, 2019 | 07:00 PM
Unhingd's Avatar
It's not necessary, but the easiest way to go since your tire installer won't have to sync new sensors to the car. Making certain you find compatible sensors can also be a challenge.
Old Apr 27, 2019 | 07:58 PM
mwinner's Avatar
Old Apr 27, 2019 | 08:00 PM
mwinner's Avatar
We ended up putting them back into the original corners, but I did take pictures of the sensors so I know which ones they are. What a difference in ride, and look from the 19”!
Old Apr 27, 2019 | 08:27 PM
Chawumba's Avatar
Looks great. Have you considered adding wheel spacers?
Old Apr 27, 2019 | 08:33 PM
mwinner's Avatar
I haven’t the wheels fit perfectly, wouldn’t spacers extend the wheel/tire outside of the wheel well? As it sits now there is room on the inside and the tire is square with the body.
what am I missing?
Old Apr 27, 2019 | 09:39 PM
Chawumba's Avatar
Typically on our cars folks are using a pretty thin spacer, 15-17 mm, so it doesn't push the wheel out past the wheel well, but it does bring it out to the point where the wheel well looks to be "filled" up by the tire. Its subtle, but can make a significant difference in appearance to those that care about such things. After you look at cars with bigger wheel offsets or stock wheels with spacers for a while, cars that have stock wheels with no spacers tend to look too "tucked in". Maybe look at some other posts where members have before and after spacer pics and see if you like the look. Just a suggestion, but either way, your new wheels are an improvement over the 19" - enjoy!
ls1swap
Dec 10, 2018 08:39 AM
Riomaa
Jul 2, 2015 12:17 PM
zdrapec
Oct 18, 2014 01:31 PM
04vdp
Jul 17, 2010 10:30 AM
