2004 XJ8 air bag airline connector leaking
Old Apr 22, 2013 | 10:04 AM
cliveross's Avatar
Default 2004 XJ8 air bag airline connector leaking
Greetings to all from a newbie to this forum. But long in the tooth in the outside world, having enjoyed and suffered many Jag's since my first 1957 2.4 sedan.
My current is a newly acquired 2004 XJ8 4.2 with 68,000 miles. My initial problems are a trunk release that only partially opens on the release button (replacement latch has been ordered) and a hissing front right air line connector on the airbag. OEM bags. I've had three Lincoln Mk8 in my vehicle history, so I've done some Re&Re in the past.
I've discovered the connector was finger tight and when tightened further it firmed up, hiss dropped and then loosened up again. I suspect stripped threads. Rather than replace the OEM bag or swap out for two Arnotts, I'm tempted to remove the connector and use epoxy such as JBweld on the threads and snug up and hope for a lasting fix.
To this end I welcome comments and perhaps someone can refresh my memory on how to release the air from the system and the air line from the connector.
Thank you in advance.
Clive
Old Apr 22, 2013 | 10:26 AM
WhiteXKR's Avatar
Where is this fitting you are looking at?
It is not the airbag. Airbags use an electrically activated chemical reaction to inflate, not an air line.
Old Apr 23, 2013 | 07:01 AM
RDMinor's Avatar
I'm pretty sure he's talking about one of the suspension 'air bags' since Arnott doesn't make protective air bags. He also mentions his previous two Lincoln's that were notorious in their day for collapsing suspension 'air bags'.
Old Apr 23, 2013 | 07:21 AM
cliveross's Avatar
Default Leaking suspension air bag
RD Minor is correct. It is the airline connector that is attached to the top of the unit that seems to have stripped threads.
Old Apr 23, 2013 | 07:42 AM
WhiteXKR's Avatar
Ahhh...thanks for the clarification.
I suggest you post in the X350 section...you will find many people there much more familiar with your model.
Welcome to the forum Clive,
Is the leaking connector shown in this Parts Catalogue graphic?
Click on it to open full size.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice on posting to the forum.
Old Apr 23, 2013 | 05:53 PM
RDMinor's Avatar
It strikes me that JB Weld is overkill and might make a subsequent repair attempt difficult & probably even more expensive. Do you think that trying some Teflon plumbers tape around the threads wouldn't be a better first try?
On which end are the threads stripped, the male or female end ? There are tons of pressure sensors for sale on eBay and as far as I've heard they aren't particularly prone to failure so they should be a safe buy used. Of course if the stripped threads are on the pressure line side that could be a bit more problematic, at least as far as replacement is concerned.
Old Apr 24, 2013 | 09:52 AM
cliveross's Avatar
Greetings Graham and RD,
First, thank you for your input. I bit the bullet and attacked it. I didn't want to end up with a failed suspension and having to order a replacement assembly.
JB weld would have been permanent for sure However it turned out that the threads were not stripped. I let the air bleed out overnight and removed the connector as shown on the diagram. The threads were perfect, so I applied some permatex RTV (blue) and reattached the airline connector and tightened up. No more hissing.
Now I just have to track down the slow coolant leak which is prevalent in some Jags. It seems so slow that it evaporates leaving little evidence of the leak source. I've inspected the expansion tank it it all seems OK.
Clive
2004 XJ8, 2012 Genesis 4.6, 1999 Porsche Boxster, 2013 Ford Focus, 2000 Honda Odyssey
kelliott
May 31, 2022 05:26 PM
Bcrary3
Sep 12, 2021 05:41 AM
cissdm
May 3, 2016 06:02 AM
sogood
Sep 15, 2015 07:35 AM
OkieTim
Sep 2, 2015 12:48 PM
