4.2s AJ-V8 external dimensions
Hi all I hope some one on here could help me i'm currently looking to fit a 4.2 supercharged v8 into my 1972 Reliant Scimitar and before I go out and buy the motor I would like to get some external dimensions if possible i have searched the net for weeks and not one single post about it so i'm here asking for your help any is appreciated.
Many thanks Carl
Many thanks Carl
I have a complete AJ33S sitting on the floor of my shop.
The SuperCharger is not mounted but I can put a tap measure to it.
It is stuck in a corner so I can't draw a detailed blue-print of the thing.
bob
bob
Engine height to highest point on cam covers.
length from rear of furthest head to front of crank pulley.
Width across heads at widest point.
And finally width of the sump unless it an S type sump then not to worry.
If you can help with any of these it would be greatly appreciated
many thanks Carl
The basic engine is really no different than the AJ26/AJ27 SuperCharged engine. The bore is the same, just the stroke is increased.
About 27" wide at the outside edges of the cam covers.(about 17" from the bottom of the oil pan)
About 24" long, torque converter drive plate to the front cover.(The crank damper sticks out farther)
I will measure more now that you posted requirements.
chrisisle
Sep 14, 2021 05:38 AM
fatty
Jan 11, 2012 06:06 AM
Softballjunnkie
Jan 2, 2010 10:32 PM
