auto locking
Old Sep 9, 2023 | 03:19 PM
Jag1956's Avatar
Default auto locking
newbie looking for help. Here's the situation: Just purchased a xj8 2000. the doors will not lock/unlock by using the remote. they key will only unlock the driver side door. There is no buttons in interior to lock/unlock the doors. doors lock upon startup and unlock when engine shuts off. I have performed a hard reset by disconnecting the neg battery terminal. I have checked the fuses. I have found the relay under rear passenger seat fuse box but have not replace it yet. I wanted to make sure before i start replacing relays if there's anything else i should do. I have read other posts on this same subject and followed advice up to replacing relays. Encourage me...
Old Sep 10, 2023 | 10:28 AM
clubairth1's Avatar
Community Influencer
Does your car have this button?
I think that's the button your looking for?
Old Sep 10, 2023 | 11:16 AM
motorcarman's Avatar
The other 3 doors WILL unlock if you turn the key in the driver's door AGAIN. (twice)
Old Sep 10, 2023 | 11:24 AM
Jag1956's Avatar
yes, i have that button. I'll have to look it up and see what it does.
Old Sep 10, 2023 | 11:26 AM
Jag1956's Avatar
I've tried that as well. I just get a chirping sound. My other Jag, x-type, will lock/unlock with that key function.
Old Sep 10, 2023 | 11:28 AM
Jag1956's Avatar
I have tried that as well. My other Jag, x-type, will lock/unlock using that function. All i get from the xj8 is a chirping sound.
Old Sep 10, 2023 | 11:51 AM
Jag1956's Avatar
That button does not work either. I'm now leaning towards a relay issue.
Old Sep 10, 2023 | 11:53 AM
Jag1956's Avatar
I've tried that, it does not work.
msobug
Jan 19, 2024 07:17 AM
Johnnyw
28
Dec 22, 2021 07:08 AM
jagmarine
Apr 9, 2021 09:00 AM
GeorgioTsukolius
Jun 10, 2016 06:30 PM
coventryfan
Dec 31, 2010 03:54 PM
