BEFORE - Asking for help, PLEASE READ!
Old Apr 29, 2010 | 06:42 PM
Exclamation BEFORE - Asking for help, PLEASE READ!
Before posting a topic asking for help on this issue or that issue, please, please make sure you cover the basics to help the techs / knowledgable members etc that may be able to help you.
In essence, Please help them to help you by provising the basic info as follows......
YOM - Year of manufacture
Model
Location - helps to identify if left hand / right hand drive
These guys don't have a crystall ball
Old May 3, 2010 | 10:58 PM
Baby_Jag's Avatar
go to my thread...
it in this sections as well..gen tech help
ihe thread is called TIE ROD QUESTION
can u help answer? please and thanks
Old Jul 29, 2010 | 08:28 PM
gracecua44's Avatar
Default Help With Rotars
I bought a used 2004 S-type R and absolutely love the car. When people told me maintenance was high, I didn't realize exactly how high they would be. I just replaced my rotars and they told me they are really soft and wear down quickly, so I'll be back doing it again soon. Are their harder metal rotars that last longer than the composites, and hopefully they would be the same price or cheaper? Is there any hope for saving money on this?
Thanks for your help.
Matt
Old Jul 29, 2010 | 08:41 PM
joycesjag's Avatar
Matt,there is another section in this forum called the "S TYPE SECTION" go to that section and be prepared to do alot of reading on your brake question. Also being a new member you can do a key word(s) search using the "Search Box" above.
Welcome to the forums and most of your questions should go to the S Type section for the fastest replies.
Old Feb 6, 2011 | 10:13 PM
2006XXXType's Avatar
Unhappy Cylinder 1 Misfire after replacing spark plugs
2006 X-Type 3.0 V6 (Left hand drive)
Decided to do some maintenance on my car and replaced the Air and fuel filter and all spark plugs but afterward it misfires on cylinder 1 only, have a code for it and its severe enough to set another code for bank 1 cats being damaged, P1313 i think.
I believe cylinder 1 is the one against the firewall nearest to the pulleys?
It flashes the check engine light on take off and misfires constantly on idle and revving the engine but once I start driving about 35mph it seems to go away. Swapped the coil and plugs from #1 to #4 (the one thats easy to get to) but it still misfired on only #1..
Here's the bad things I think I did:
Used Bosch 4 tip uranium plutonium unobtainium plugs from pepboys but then why would that cause only #1 to misfire?
Also didn't replace the green intake gaskets but then again would that cause a misfire on more than just #1?
Any help would be appreciated guys, I guess I'll do a compression test on cylinder 1 tomorrow morning so that means I get to take off the intake manifold for a third time yaaaay
Also read in some other threads leaky injector could be to blame, this is my next area to focus on how can I check it? I was planning to use a stethoscope to listen to it activating
Old Feb 7, 2011 | 05:16 AM
Cadillac's Avatar
I am locking this thread for convenience . If you have questions please use relevant forum or General Tech Help
Old Nov 7, 2011 | 04:16 AM
Originally Posted by JimC64
Before posting a topic asking for help on this issue or that issue, please, please make sure you cover the basics to help the techs / knowledgeable members etc that may be able to help you.
In essence, Please help them to help you by providing the basic info as follows......
In the Title of your thread.
Model
Hi folks, since we expanded the forum in early summer, we now have sub-sections covering all the popular models.
If you have a question/problem/observation about a specific model, please will you scroll down to the Specific Model section and make your post in there.
You are much more likely to attract the attention of people who have the experience and knowledge to help you.
Over the course of the next few weeks, we are going to be making an effort to move Model specific threads from this General section into their correct Model sections. (probably a 4 Weetabix job)
The aim is to leave this section as a General non specific area, and more importantly, help reduce the number of posts that are not receiving prompt replies.
Please help us out and make your Model specific posts in the appropriate sub forums.
If you are unsure of which model you have, simply send a PM to myself or any of the Mod's.
Include as much detail in the title as you can. eg, 96 XJ, and we will help you along.
Thanks for all your help.
Old Nov 17, 2011 | 08:32 PM
When making a post asking for help, PLEASE BEAR IN MIND THE FOLLOWING..........
Be sure to include the Model, Year or manufacture and location as a minimum.....The model and Y.O.M in the thread title if at all possible
This will really help us at a future date when it comes time to migrate these threads to the forum section where they belong!
Thanks in advance for your help in this
Old Nov 19, 2011 | 12:59 PM
Daily BUMP.
Old Nov 19, 2011 | 08:01 PM
Originally Posted by jimc64
when making a post asking for help, please bear in mind the following..........
be sure to include the model, year or manufacture and location as a minimum.....the model and y.o.m in the thread title if at all possible
this will really help us at a future date when it comes time to migrate these threads to the forum section where they belong!
thanks in advance for your help in this
please read!!
Old Nov 30, 2011 | 02:51 AM
To the top.
Old Jan 9, 2012 | 02:08 PM
Note, threads moved from this section over to Specific Model sections, will not generally carry a notification of the move.
Old Jul 30, 2013 | 03:09 AM
Bump.
trosty
26
Dec 18, 2022 06:40 PM
philwarner
25
Jun 26, 2021 05:43 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
explorer364
Sep 14, 2015 07:43 PM
1100me
Sep 7, 2015 06:26 AM
