Brake fluid test strips
Old Sep 23, 2013 | 11:43 AM
Doug's Avatar
Default Brake fluid test strips
Anyone here using test strips?
Comments, thoughts? What brand?
For ages I've been a every-two-years-or-30k-miles-brake-flush-guy. No complaints; it's always served me well. But I'm pondering a more thoughtful approach.
Cheers and thanks
Old Sep 23, 2013 | 12:53 PM
Maninahat98's Avatar
Cheers and thanks
Not seen these strips - what do they test for? Water content? Contamination ? something else? Thanks, Allan
Old Sep 23, 2013 | 07:47 PM
Doug's Avatar
Water, metallic content, other "stuff". I've just begun researching them
Old Sep 24, 2013 | 09:18 AM
MRomanik's Avatar
Veteran: Air Force
I've seen them in the auto parts stores but never used them. I believe they were pricey.
Old Sep 24, 2013 | 10:45 AM
Mikey's Avatar
Please keep us posted!
Old Sep 24, 2013 | 07:52 PM
QuartzSTypeR's Avatar
Typically they are used to test for copper content in your brake fluid. When there is excessive copper found in your brake fluid, it is an indication that the corrosion inhibitors in your brake fluid are breaking down (brake fluid breaks down just like every other fluid in your car). Here is a good article on it: Brake Fluid Testing: Bleeding and Flushing Minimizes Internal Corrosion in the Brake System: Brake and Front End
Old Oct 3, 2013 | 08:35 PM
tjac357's Avatar
Brake fluid is hydroscopic (absorbs water), as brake fluid ages it absorbs water in humidity from the air then looses it's hydroscopic ability. Brake fluid test strips test the ability of the fluid to absorb moisture. Brake fluid needs to absorb moisture to protect the internals of the hydraulic components of the brake system from rust or corrosion. If brake fluid has lost its ability to absorb moisture that can cause accelerated failure of hydraulic components of the brake system.
aholbro1
Dec 29, 2024 06:46 PM
GordoCatCar
Jan 2, 2017 01:10 PM
SeanU
Sep 13, 2015 02:45 PM
Richard_gib
Sep 12, 2015 07:08 PM
Jay48
Sep 7, 2015 09:30 PM
