CAN Bus troubleshoot
Old Feb 4, 2019 | 07:20 AM
Xnodrk's Avatar
Default CAN Bus troubleshoot
Hello,
I'm trying to fix a problem in the CAN bus ( U1900 and other node missing etc...)
I have 12.7 V on ignition off
I have 2.7 V on CAN_H and 2.4 V on CAN_L which seems to be good
But when i mesure the resistance between H and L , i have 0 ...
is it possible ? or my DVOM is dead ? ( or at least , not having his ohmmeter function ...)
Also , i don't seem to find the main connectors wiring, its like a big cube ... with many wires, one on right up from fuse box , and one on left, i don't find the name
Thx
Old Feb 6, 2019 | 06:12 AM
JagV8's Avatar
It's you DVOM or how you use it - think about it: you can't have different CAN_H & CAN_L if the ohms are zero.
Old Feb 10, 2019 | 08:25 AM
clubairth1's Avatar
Community Influencer
Unless you have an SDD and know how to use it you are just shooting in the dark.
It's just WAY to complicated to try and troubleshoot a CAN bus with stone age tools.
Old Feb 11, 2019 | 03:45 AM
Xnodrk's Avatar
Hello,
I have SDD ... i bought a new power supply 30 A 9mv ripple , reinstalled SDD, removed firefox ( SDD works better with Internet Explorer)
I ordered some piercing probes / Needle probes
Also I ordered new DVOM , i found 60 ohm between pin 6 and 14 from Data Link Connector and correct voltage
Next step is to test the CAN lines continuity between ABS/DSC module ( on MY2009 there seems to be only 1 module refered as DSC module) Junction Box
thx
davejdoyle
May 6, 2016 11:54 AM
ace911emt
Mar 22, 2012 10:57 AM
HectorM52
Jan 4, 2012 10:57 PM
tzvangel
Jan 28, 2011 02:20 PM
04blackxjr
Sep 27, 2010 04:20 PM
