ECU questions
Old Apr 10, 2015 | 08:06 AM
Gimby's Avatar
Default ECU questions
Dear Techies, please help.
55plate 2.7 TDI S-type that wont start. Check relevant sensors CPS/CKS/IFS/fuel delivery and need to check FPS/FVC etc.
Was wondering if ECU could be at fault. Car was witnessed running with Easystart only i.e would not continue running.
Q1) Do ECU physically fail or can they get corrupted s/w
Q2) is there a way to tell what firmware the ECU has and what the latest release is.
Q3) If yes to above can ECU be re-programmed / flashed using OBD tools.
Thx Paul
Old Apr 10, 2015 | 03:57 PM
JagV8's Avatar
Should be in the S-Type forum - maybe a mod will move it.
But... no diesel S-Types in USA/Canada and the 2.7D uses a different PCM to any of the others. For those, the PCM is almost 100% reliable and the very last place to look.
Yours isn't even the same make so no idea.
Bcrary3
Sep 12, 2021 05:41 AM
Johncy2000
Dec 22, 2017 04:32 PM
Charlene n John
Sep 14, 2015 12:01 AM
explorer364
Sep 11, 2015 05:44 PM
joesoap
Sep 10, 2015 01:09 PM
