Fog Lights for MK II
Old Jul 2, 2012 | 05:42 PM
GaryBHigbee's Avatar
Default Fog Lights for MK II
I have a 1960 MK II that does not have for lights and would like to add them. I called Moss Motors, however they do not seem to carry them. Any suggestions on where I might obtain the lights and whatever else might be needed. Much thanks.
Old Jul 3, 2012 | 03:38 AM
Cadillac's Avatar
I know two great sources :
www.motorcarsltd.com
www.jagbits.com
You can also look at ebay.com
Old Jul 4, 2012 | 09:34 AM
Thanks. I will check them out.
Gary
Old Jul 5, 2012 | 04:47 AM
Fraser Mitchell's Avatar
These lamps can be very expensive, but here is a US site with repro ones.
http://jollyrogersmotors.com/node/213
The lamps are called Fograngers, and I think there was also a lamp called a Spotranger in the same lamp body at one time. Lucas made them originally. For a Mark 2, they fit in the hollow recesses at the front below the headlamps, and you need a backing plate to fit them correctly so the lamp can be adjusted. Where a car did not have them, (it was an optional extra), the recesses are filled with chrome-plated mazak mock grills Make sure you check the mounting plates come with the lamps. If not you will need to find some from somewhere. Old ones can be replated.
Old Jul 6, 2012 | 08:36 AM
Thank you for the information.
Gary
Old Aug 1, 2012 | 04:37 PM
Jose's Avatar
if you want an inexpensive solution, contact Rock Browning at Mr. Jaguar.com, he makes them for S type and MK-2. (he made a pair of custom driving lights for my S type to fit in the original buckets, since they are larger in the S type than in the Mk-2).
The lamps he sells install in the original bucket left and right of the grille. Forget the Fog Rangers, they were very inneficient, more decorative than anything.
Porsche Air Conditioning & Jaguar Air Conditioning
Old Aug 1, 2012 | 04:52 PM
They do look good, though. I don't think I ever turned mine on more than twice ! We don't seem to get the fogs we used to get in the old days here in England.
Old Aug 2, 2012 | 03:04 PM
Jose's Avatar
the ones sold by Mr. Jaguar / RetroAir look similar to the Fog Rangers. look at the ones he made for my S type (5" diameter each with 100 watt bulbs each). They are driving/spot lights, not fogs, and they are more powerful than the High beams.
Old Aug 2, 2012 | 03:42 PM
Thanks for the information.
Gary Higbee
Old Aug 2, 2012 | 03:44 PM
Thanks to everyone that quoted on the fog lamps.
Jpav27
Jul 31, 2022 06:43 AM
redrover41
23
Sep 25, 2015 01:33 PM
motorhead69
Sep 9, 2015 10:04 AM
avern1
Sep 6, 2015 04:22 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
