Fuel Line for Brake Line?
Old Dec 15, 2012 | 02:18 PM
Jagxjs's Avatar
Default Fuel Line for Brake Line?
I need to cut 4 short pieces of rubber hose for the non-pressurized brake lines from the reservoir to the master cylinder. No one in town seems to have brake specific rubber hose, but I was told high quality fuel line will work just as well.
Thoughts?
Old Dec 16, 2012 | 02:47 AM
I know EXACTLY the pieces you are referring to, and YES, it will suffice.
Eventually the brake fluid will "leech" thru this hose, but it takes about 12 months.
I use EFI rated 6mm hose, and have never had fluid contamination issues. On our S2 and XJ-S I eliminated those metal pipes and simple ran that hose from the container to the master cylinder direct, less joints to weep was my thinking.
Old Dec 16, 2012 | 04:43 AM
plums's Avatar
You could always buy a brake hose with the ends on it and just cut what you need from it. Of course you need to ensure that the ID is right.
Old Dec 16, 2012 | 09:54 AM
Mikey's Avatar
+1 on this. There's too much variation in the materials used in generic fuel line, no guarantee that they all will stand up to quirks of brake fluid.
Old Dec 17, 2012 | 05:06 AM
Jagxjs's Avatar
Thanks to you all. I wnet with the blue braided clutch/brake liners often used for porsche/vw applications. Now, I just need to find a suitable gasket for my reservoir cap. So far, no good.
I am getting there. "If it was easy, anyone could do it."
clubairth1
30
Sep 3, 2025 04:38 PM
Razor
Aug 28, 2019 08:34 PM
explorer364
Sep 11, 2015 05:44 PM
1964Daimler
Sep 9, 2015 04:50 PM
1964Daimler
Sep 9, 2015 11:28 AM
