Jag techs on site
Old May 9, 2010 | 11:49 AM
  #41
H20boy's Avatar
Jim, I say 'badge him' and let him ask us to remove if he gets too poplular.
I'm gonna come visit you Bob! (someday)
Old May 11, 2010 | 09:07 PM
  #42
motorcarman's Avatar
"BADGES????? WE DON'T NEED NO STINKING BADGES!!!!!
I'll still answer all the questions I have an answer to.
bob gauff
Old Jun 25, 2010 | 08:06 PM
  #43
Gus's Avatar
Gus
bob gauff
Bob,
I figured you were skilled! This is good to know and would welcome seeing you badged, you deserve it.
Old Sep 13, 2010 | 07:46 PM
  #44
Bob, please accept my sincere apologies for the delay......life's kinda getting in the way of things at the moment....lol
Personally, I blame the mods, they should be shouting to get someone like you badged and harrass the hell outta me to get it done
You have been BADGED
On a side note - Anyone seen with " ** TECH CERTIFIED ** " in their member profile as opposed to the "official" style badge will have it removed!
These badges are generally NOT just handed out ***** nilly, but usually to those with knowledge and experience to spare / share and that have been recommended by either a few members or a mod, or one that has generally answered every tech request for help and then some!
Old Sep 16, 2010 | 10:28 PM
  #45
H20boy's Avatar
Hey hey, new badge looks good under the old 'motorcarman' name!
Old Sep 16, 2010 | 10:36 PM
  #46
Gus's Avatar
Gus
Kudos to Bob!
Old Sep 21, 2010 | 11:33 AM
  #47
I can't believe I missed this momentous event.
Good to see that you have been 'CERTIFIED' Bob.
Nice one.
Old Oct 13, 2010 | 02:25 PM
  #48
richlau's Avatar
2001 xj8 gear box fault. Car stuck in 3rd gear. Any suggestions.
Old Oct 13, 2010 | 02:31 PM
  #49
richlau's Avatar
2001 xj8, gear box fault, car stuck in 3rd gear. Any suggestions?
Old Oct 13, 2010 | 04:21 PM
  #50
Gus's Avatar
Gus
What OBD codes do you have?
Old Oct 14, 2010 | 06:23 PM
  #51
eoevictor's Avatar
Red face Vct
my mechanic removed the VTC on a 2002 s type 4.0 with out the cam alignment tool! now the cam is advanced. i know it should have been taken apart with the cam alignment tool to secure it in place. so the question is. How do i find the correct position for the VTC? or how do i get the VTC internally aligned again?
Old Oct 14, 2010 | 06:48 PM
  #52
steve11's Avatar
ud
1. Remove both cam covers
2. Rotate the crankshaft CLOCKWISE (only, never anti-clockwise) until the four cam flats (two pairs) are in two common planes. If all four do not line up then the cam that doesn't (one of the exhaust cams) is the one out of time. If all line up then the engine is timed correctly. If not:
3. Pin the crankshaft using the proper timing hole (crankshaft tool part of the timing tool set). If needed, rotate the crankshaft through two full turns if the crank is advanced past the hole.
4. Once the crankshaft is stabilized, loosen the exhaust sprocket bolt(s) on the the exhaust cam(s) that are out not on the same planes as the intake cams.
5. When the bolts are loosened, place the cam hold down fixtures in place.
6. Retighten the exhaust sprocket bolts as the cams are pinned making sure to use the spanner wrench (part of the kit) to take the slack from the driven side of the sprockets.
7. Remove the crank pin and rotate the crankshaft clockwise two turns and ensure the cam flats (2 pairs in two common planes) are still in alignment
8. Replace the cam covers
9. You're done.
Old Oct 14, 2010 | 08:08 PM
  #53
Here below, for quick and easy reference is an up to date list of ALL Jagetchs that have been or are currently on site.
I will do my best to try and keep this as up to date as possible for the benefit of all. In the event that there are any changes that have gone unnoticed, please pm / email me so I can amend ASAP.
I don't think I've missed anyone. If I have, accept my apologies and please advise me so I can rectify immediately.
If they're active, they've signed on within the last 90 days.
Size:  2.9 KB Brutal - CURRENTLY ACTIVE
Size:  2.9 KB myglimk2- CURRENTLY ACTIVE
Size:  2.9 KB Real_tech -CURRENTLY ACTIVE
Size:  2.9 KB Jagtechohio - CURRENTLY ACTIVE
Size:  2.9 KB jag_genius - CURRENTLY ACTIVE
Size:  2.9 KB Teck4jag - CURRENTLY ACTIVE
Size:  2.9 KB Bulldoze - CURRENTLY INACTIVE
Size:  2.9 KB FactoryJaguarTech - CURRENTLY ACTIVE
Size:  2.9 KB Jaggachafen - CURRENTLY ACTIVE
Size:  2.9 KB ibjags - CURRENTLY ACTIVE
Size:  2.9 KB Poboyblues - CURRENTLY INACTIVE
Size:  2.9 KB motorcarman - CURRENTLY ACTIVE
Size:  2.9 KB JustV12 - CURRENTLY ACTIVE
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Last edited by H20boy; Oct 16, 2010 at 10:52 AM. Reason: thread locked so as not to get diluted any further & UPDATED 16-10-10
Old Oct 16, 2010 | 10:51 AM
  #54
H20boy's Avatar
Richard, you could edit Jim's post...I did
Matt you are correct, thanks for doing this, Rich.
Added the new guys, well deserved recognition for sure!
List of Active Techs
- If they're active, they've signed on within the last 90 days.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old May 24, 2011 | 07:53 PM
  #55
Size:  2.9 KB myglimk2- CURRENTLY INACTIVE
Size:  2.9 KB Real_tech -CURRENTLY INACTIVE
Size:  2.9 KB Jagtechohio - CURRENTLY INACTIVE
Size:  2.9 KB FactoryJaguarTech - CURRENTLY INACTIVE
Size:  2.9 KB XJRguy - CURRENTLY ACTIVE
Size:  2.9 KB BlackX300VDP - CURRENTLY ACTIVE
Size:  2.9 KB Daxter1987 - CURRENTLY ACTIVE
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Apr 1, 2012 | 12:30 PM
  #56
CONTENT ADDED 01.04.2012
slojotaa
Oct 16, 2019 10:22 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
Holden
Sep 5, 2015 03:29 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 07:47 PM
obwoodie
Sep 3, 2015 07:45 PM
