Jaguar Module & Sensor Acronyms, need some of these deciphered
I'm getting together a list of modules/sensors that my AutoEngenuity program monitors/controls, and many of these I can't figure out myself.
Instead of making myself look ridiculous, I've only completed the ones I am for sure I got correct.
For the rest, can each of you copy and paste the list, as it it is progressively filled in from post to post.
It will be a good addition to our main Acronym thread that we are compiling, so its going to be used over and over again in the future.
thanks in advance!
ABS - AntiLock Brake System
ABS II - AntiLock Brake System 2
ABSSCP -
ACC -
ACM -
ADCM -
ADHLS -
ADHLS_L -
ADHLS_R -
ADRC -
AHCM -
AMP - Amplifier
ARM-
ASU-
ATC-
ATCISO-
BPM-
BPMISO-
CCM-
CCMCAN-
CMM-
CPM-
DDM-
DHM -
DRDM-
DSM-
ECMSCP-
EPB-
FEM-
FETM-
GEM-
HCM-
ICCM-
ICCM II -
ICE-
IPK-
ISM-
MCCM-
NAV - Navigation
PAM-
PBM - Parking Brake Module
PCM-
PCM II-
PCMISO -
PCMPTEC -
PDM-
PHM-
PRDM-
PSM-
RCM-
RCMISO-
RCMSCP-
REM-
RSM-
SCLM -
SLM-
TCM - Transmission Control Module
TCM II - Transmission Control Module 2
TCM III - Transmission Control Module 3
TCMISO -
TPM -
Here are a list of the module/sensor features that may give you some hints as to it's true definition.
thanks in advance!
ABSSCP -
ACC -
ACM -
ADCM -
ADHLS -
ADHLS_L -
ADHLS_R -
ADRC -
AHCM -
AMP - Amplifier
ARM-
ASU-
ATC-
ATCISO-
BPM-
BPMISO-
CCM-
CCMCAN-
CMM-
CPM-
DDM-
DHM -
DRDM-
DSM-
ECMSCP-
EPB-
FEM-
FETM-
GEM-
HCM-
ICCM-
ICCM II -
ICE-
IPK-
ISM-
MCCM-
NAV - Navigation
PAM-
PCM-
PCM II-
PCMISO -
PCMPTEC -
PDM-
PHM-
PRDM-
PSM-
RCM-
RCMISO-
RCMSCP-
REM-
RSM-
SCLM -
SLM-
TCMISO -
TPM -
ABSSCP - Antilock Brake system Speed Control Processor
ACC - Accessory
ACM - Audio Control Module
ADCM - Active Dampening Control Module
ADHLS - Axle Deflection Height Level System
ADHLS_L - Axle Deflection Height Level System Left
ADHLS_R - Axle Deflection Height Level System Right
ADRC -
AHCM -
AMP - Amplifier
ARM- Automatic Restraint Module
ASU- Automatic Suspension unit
ATC- Automatic Temperature Control (cabin A/C-heater controls)
ATCISO- Automatic Temperature Control ISO bus
BPM-Body Processor Module
BPMISO- Body Processor Module ISO bus
CCM- Climate Control Module
CCMCAN- Climate Control Module CAN communications bus
CMM -
CPM- Cellular PHone Module
DDM- Driver's Door Module
DHM - Driver's Head (Restraint) Module
DRDM- Driver's Rear Door Module
DSM- Driver's Seat Module
ECMSCP- Engine Control Module Speed Control processor
EPB- Electric Parking Brake
FEM- Forward/Front Electronics Module
FETM- Front Entertainment Module
GEM- Generic Electronics (control) Module
HCM- High Speed CAN Network Module
ICCM- Instrument Control Center Module (ie, instrument cluster)
ICCM II - Instrument Control Center Module 2
ICE- In-Car Entertainment
IPK -
ISM -
MCCM- Message Control Center Module (ie, tripometer, odometer, etc)
NAV - Navigation
PAM- parking Aide Module
PCM- Powertrain Control Module
PCM II- Power Train Control Module 2
PCMISO - Power Train Control Module ISO bus
PCMPTEC - Powertrain Control Module, security (PATS), Throttle Electronics Module
PDM- Passenger Door Module
PHM- Passenger Head restraint Module
PRDM- Passenger Rear Door Module
PSM- Passenger Side Module
RCM- Resistance Deployment Control Module (ie, second generation airbag control module)
RCMISO- Resistance Deployment Control Module ISO bus
RCMSCP-REsistance Deployment Control Module Secondary Control Processor
REM- Rear Electronics Module
RSM- Rear head Restraint Module
SCLM -Steering column Locking Module
SLM -
TCMISO - Transmission Control Module-ISO bus
TPM - Tire Pressure Monitoring
That gets most of them. A few I got all the listing of what it monitors, but did not see a listing of what the letters stood for. Kinda like the SLM is dealing with the rear tail lights, but also covers the gas cover cap position, convertible top controls, etc.
ACC - Accessory
ADRC -
AHCM -
AMP - Amplifier
CMM -
IPK -
ISM -
NAV - Navigation
SLM -
ADRC - Adaptive Damping Ride Control Module
AHCM - ?...it's an engine module of some sort that seems to be related to heat
CMM - Column Memory & Mirror Control Module?
IPK - Instrument Pack?
ISM - Intrusion Sensor?
SLM - Security Locking Module?
These are from a flyer that pitches the "AutoLogic Diagnostic Tool" for Jaguar....among other makes. They are just expansions of the acronym so I've left the "?" there.
Eric
Eric
Ooohh, good ones Eric, I think you're right on. I remember recently reading the Security Locking Module in jag documents.
Now, what is that very last one?
I may send a PM to Brutal, stevetech, and Bob (motorcarman) to see if they have time to review, and make sure we haven't made any goofs.
ACC - Accessory
AHCM -
AMP - Amplifier
NAV - Navigation
ACC - Accessory
AHCM -
AMP - Amplifier
NAV - Navigation
There will be some dups in here, but right out of the DTCs and Electrical guides:
CONTROL MODULE AND GENERAL ACRONYMS:
AMP Power Amplifier
ASCM Adaptive Speed Control Module
ASM Air Suspension Module
AUDIO Audio Unit
CATS Computer Active Suspension System
CCM Climate Control Module
CPM Cellular Phone Module
DDM Driver Door Module
DSCM Dynamic Stability Control Module
DSM Driver Seat Module
ECM Engine Control Module
FEM Front Electronic Module
HLM Headlamp Leveling Module
IC Instrument Cluster
IS Intrusion Sensor
JGM J-Gate Module
MCP Multimedia Control Panel
NCM Navigation Control Module
PAM Parking Aid Module
PATS Passive Anti-Theft System
PBM Parking Brake Module
RCCM Rear Climate Control Module
RCM Restraints Control Module
REM Rear Electronic Module
RMM Rear Memory Module
SCLM Steering Column Lock Module
TCM Transmission Control Module
VAM Voice Activation Module
VICS Vehicle Information Control System
POWERTRAIN CONTROL ACRONYMS:
A/C Air conditioning
APP Sensor Accelerator Pedal Position Sensor
ASC Adaptive Speed Control
B+ Battery Voltage
Bank 1 RH Engine cylinder bank (cylinders 1, 3, 5, 7) (A Bank)
Bank 2 LH Engine cylinder bank (cylinders 2, 4, 6, 8) (B Bank)
BARO Sensor Barometric Pressure Sensor
CAN Controller Area Network
CKP Sensor Crankshaft Position Sensor
CMP Sensor 1 Camshaft Position Sensor – Bank 1
CMP Sensor 2 Camshaft Position Sensor – Bank 2
DLC Data Link Connector
DSC Dynamic Stability Control
ECT Sensor Engine Coolant Temperature Sensor
EFT Sensor Engine Fuel Temperature Sensor
EGR Exhaust Gas Recirculation
EOT Sensor Engine Oil Temperature Sensor
EVAP Canister Close Valve Evaporative Emission Canister Close Valve
EVAP Canister Purge Valve Evaporative Emission Canister Purge Valve
FTP Sensor Fuel Tank Pressure Sensor
HO2 Sensor 1 / 1 Heated Oxygen Sensor – Bank 1 / Upstream
HO2 Sensor 1 / 2 Heated Oxygen Sensor – Bank 1 / Downstream
HO2 Sensor 2 / 1 Heated Oxygen Sensor – Bank 2 / Upstream
HO2 Sensor 2 / 2 Heated Oxygen Sensor – Bank 2 / Downstream
IAT Sensor Intake Air Temperature Sensor
IMT Valve 1 Intake Manifold Tuning Valve: Bottom
IMT Valve 2 Intake Manifold Tuning Valve: Top
IP Sensor Injection Pressure Sensor
KS 1 Knock Sensor – Bank 1
KS 2 Knock Sensor – Bank 2
MAF Sensor Mass Air Flow Sensor
MAP Sensor Manifold Absolute Pressure Sensor
N/A Normally Aspirated
SC Supercharged
TCC Torque converter clutch
TFT Sensor Transmission Fluid Temperature Sensor
TP Sensor Throttle Position Sensor
V6 V6 Engine
V8 V8 Engine
VVT Solenoid Valve 1 Variable Valve Timing Solenoid Valve – Bank 1
VVT Solenoid Valve 2 Variable Valve Timing Solenoid Valve – Bank 2
AMP Power Amplifier
AUDIO Audio Unit
IS Intrusion Sensor
JGM J-Gate Module
B+ Battery Voltage
SC Supercharged
V6 V6 Engine
V8 V8 Engine
General and EMS Acronyms
A/C Air Conditioning
APP SENSOR Accelerator Pedal Position Sensor
APP1 Accelerator Pedal Position Sensor Element 1
APP2 Accelerator Pedal Position Sensor Element 2
B+ Battery Voltage
BANK 1 RH Cylinder Bank (Cylinders 1, 3, 5, 7)
BANK 2 LH Cylinder Bank (Cylinders 2, 4, 6, 8)
CKP SENSOR Crankshaft Position Sensor
CMP SENSOR / 1 Camshaft Position Sensor / RH Bank
CMP SENSOR / 2 Camshaft Position Sensor / LH Bank
D2B D2B Network
ECT SENSOR Engine Coolant Temperature Sensor
EFT SENSOR Engine Fuel Temperature Sensor
EGR VALVE Exhaust Gas Recirculation Valve
EGT SENSOR Exhaust Gas Temperature Sensor
EOT SENSOR Engine Oil Temperature Sensor
EVAP CANISTER CLOSE VALVE Evaporative Emission Canister Close Valve
EVAP CANISTER PURGE VALVE Evaporative Emission Canister Purge Valve
FTP SENSOR Fuel Tank Pressure Sensor
GPS Global Positioning System
HID High Intensity Discharge
HO2 SENSOR 1 / 1 Heated Oxygen Sensor – RH Bank / Upstream
HO2 SENSOR 1 / 2 Heated Oxygen Sensor – RH Bank / Downstream
HO2 SENSOR 2 / 1 Heated Oxygen Sensor – LH Bank / Upstream
HO2 SENSOR 2 / 2 Heated Oxygen Sensor – LH Bank / Downstream
IAT SENSOR Intake Air Temperature Sensor
ICE In-Car Entertainment System
IMT VALVE / 1 Intake Manifold Tuning Valve / Top
IMT VALVE / 2 Intake Manifold Tuning Valve / Bottom
IP SENSOR Injection Pressure Sensor
KS / 1 Knock Sensor / RH Bank
KS / 2 Knock Sensor / LH Bank
LH Left Hand
LHD Left Hand Drive
MAF SENSOR Mass Air Flow Sensor
MAP SENSOR Manifold Absolute Pressure Sensor
NAS North American Specification
PWM Pulse Width Modulated
RH Right Hand
RHD Right Hand Drive
ROW Rest of World
SC Supercharged
SCP Standard Corporate Protocol Network
TP SENSOR Throttle Position Sensor
TP1 Throttle Position Sensor Element 1
TP2 Throttle Position Sensor Element 2
TURN Turn Signal
TV Television
V6 V6 Engine
V8 V8 Engine
VVT VALVE / 1 Variable Valve Timing Valve / Bank 1
VVT VALVE / 2 Variable Valve Timing Valve / Bank 2
+ve Positive
–ve Negative
B+ Battery Voltage
D2B D2B Network
LH Left Hand
LHD Left Hand Drive
RH Right Hand
ROW Rest of World
SC Supercharged
TURN Turn Signal
TV Television
V6 V6 Engine
V8 V8 Engine
+ve Positive
–ve Negative
Control Module Acronyms
AUDIO Audio Unit
JGM J-Gate Module
VAM Voice Activation ModuleASM Air Suspension Module
AUDIO Audio Unit
JGM J-Gate Module
ACC - Accessory
AHCM -
AMP - Amplifier
FFH- Fuel Fired Heater
GWM-Gateway Module
IP-Instrument Panel
ISM - Intrusion Sensor Module
NAV - Navigation
VACM-Voice Activation Control Module
Welcome to the forum Bladevane,
It's never too late for additional information!
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
ACC - Adaptive Cruise Control
AHCM -
AMP - Amplifier
GWM-Gateway Module
IP-Instrument Panel
NAV - Navigation
AHCM -
AMP - Amplifier
GWM-Gateway Module
IP-Instrument Panel
NAV - Navigation
From AutoEnginuity Jag Sensors:
AHCM Sensors
Burning Time - Burning Time - Hours Burning Time - Burning Time - Minutes
Control Module Power Supply Voltage Coolant Temperature
Engine Status - Engine Running External Temperature
Fuel Burning Heater Control Status - Combustion
Air Fan Fuel Burning Heater Control Status - External Relay Control
Fuel Burning Heater Control Status - Fuel
Preheating Fuel Burning Heater Control Status - Fuel Pump
Fuel Burning Heater Control Status - Glow Plug Fuel Burning Heater Control Status - Water Pump
Fuel Burning Heater Internal Moore State Global Real Time
Glow Plug Duty Cycle Heater Fan Adjustment
In-car Temperature Low Voltage Threshold
Main Engine Control Module Voltage Supply Number Of Trouble Codes Set Due To Diagnostic Test
Operating Voltage Prime Time Counter - Cumulative Count Of Priming Seconds
Achieved
Running Time - Running Time - hours Running Time - Running Time - minutes
Total Distance Webasto Error Counter
AHCM Sensors (continued)
Webasto Error Counter Parking Heater Webasto Operating State
Webasto Private Bus Failure Code Webasto Start Count
Webasto Start Count Parking Heater Webasto Start Count Supplementary Heater
AHCM Sensors
Achieved
BrentGardner
29
Dec 16, 2024 12:13 AM
hafren
Aug 30, 2023 03:42 PM
