problem to configure Powertrain Control Module
I use JLR SDD 130 with Mangoose pro
The concerned car is X-type 2.5 MY2007 Estate
The car was showing some codes that made me suspect the ECM,, and I thus made a diagnostic test checksum verification of the ECM. This verification failed (aborted) and after this event the ECM would not reply any more. Of course the engine does not start, but also the module does not answer when asked for the VIN.
I thus decided to configure Powertrain Control Module. I tried several times with different delays but it fails after about 6 seconds after the last "ignition on" (after deconnect/reconnect the battery). No Mangoose error (icon is still green), Battery is under generator (green light). I also cleaned the plug of the ECM with contact cleaner.
Any idea on what could happen ?
Many thanks in advance !
You need to read up on the VID block. You should have saved the original VID block before 'configuring' any module on the CAN bus.
Jaguar issued 'Tech-Tips' for a few years for common procedures.
There is a way to recover the ECM with the ECM rectification procedure. Hope it all works out.
JCalhoun
Mar 23, 2021 05:24 AM
Lance30144
Mar 18, 2013 03:30 AM
