Are the serpentine belts reliable on a 2001 XK8?
Old Jun 19, 2015 | 06:43 PM
cyber3d's Avatar
Default Are the serpentine belts reliable on a 2001 XK8?
I read somewhere online that the serpentine belt will fail without notice. My belt has no visible cracks and has good tension. I wonder, should it be replaced at regular intervals?
Old Jun 19, 2015 | 11:02 PM
Down here we replace the Serp belts every 100K kms, or 5 years, whichever is first.
The pulleys, mainly due to wear in the bearings are replaced at the same time.
Some consider this an overkill, but I do not.
The belts I use are Gates, and the pulleys are whatever I need of the "generic: brand that I find in stock at work, usually "Nuline" brand. Aftermarket in the USA has a better coverage than the mobs down here.
Old Jun 20, 2015 | 12:59 AM
The recommendation published in Jaguar Maintenance Schedules is:
1. check drive belt ever 10k miles/12 months - replace if necessary
2. replace drive belt every 100k miles/5 years
These intervals are on a mileage or time elapsed basis - whichever comes first.
If my belt shows cracks or it squeals, then it gets replaced.
Old Jun 20, 2015 | 02:23 AM
cyber3d's Avatar
Do you guys recommend I stick to OEM belts or are they all the same quality?
Amazon has ACDelco 7K922 Professional V-Ribbed Serpentine Belt for about $35
Old Jun 20, 2015 | 03:02 AM
Although I generally favour using OE Jaguar parts, I do use aftermarket pads and belts because of the outrageous cost of these from Jaguar. Never had any issues with aftermarket equivalents.
Old Jun 20, 2015 | 03:06 AM
As Graham said +heaps.
Do your homework, it is easy with the WWW, and I use aftermarket "known brands" 99% of the time.
Old Jun 23, 2015 | 03:55 AM
plums's Avatar
ACDelco is not a belt manufacturer.
Gates, Dayco, Goodyear are.
As long as the pulleys/idlers are stable, the belts seem very reliable.
Old Jun 23, 2015 | 08:29 AM
Originally Posted by plums
.......... As long as the pulleys/idlers are stable, the belts seem very reliable.
+1
YES - pulley/idler is a known failure and will soon wreck an otherwise good belt.
pilot435
Apr 8, 2016 06:16 PM
42Ajd
Dec 30, 2015 09:45 AM
picard
Oct 12, 2015 11:56 AM
42Ajd
Sep 21, 2015 07:37 PM
Celticblood
Sep 14, 2015 07:30 PM
