Supercharger belt impacting brakes?
Old Jul 27, 2021 | 09:17 PM
Flerkin's Avatar
Default Supercharger belt impacting brakes?
Hi, question for you all:
Had a engine replaced recently and they didn't align the pulleys properly for supercharger belt...belt shredded and lost supercharger. A couple of days later the breaks went out while belt was still off. Dealership says the belt somehow impacted the brakes and that's why they went out. Does that make any sense at all?
Thanks,
Chris
2021 F-Type R
Old Jul 27, 2021 | 10:06 PM
OzXFR's Avatar
Only two ways I can think of:
1. The shredded belt hit a brake line and squashed or busted it.
2. The brake master cylinder lost vacuum seeing as it draws it's vacuum from a line connected to the back of the SC.
Old Jul 28, 2021 | 06:37 AM
Flerkin's Avatar
OzXFR,
Thanks, that makes sense now. Doubt it was the line squash issue, guessing that it was the vacuum issue as the belt was off for a couple of days and the brakes worked fine. Then I didn't drive for a day and they went out.
-Chris
Old Jul 29, 2021 | 11:51 AM
clubairth1's Avatar
Community Influencer
I thought the current SC cars used a gear driven vacuum pump mounted on the front of the engine?
At least my 5.0L V-8 does??
Why would the belt breaking or getting shredded tear up the super charger? I had a locked idler pulley happen on my old S Type R. Ripped the belt in two but other than that did no other damage at all? Not understanding how the belt coming apart could cause these other problems?
Old Jul 30, 2021 | 10:37 AM
Flerkin's Avatar
The only real damage was the brakes going out from the belt coming off. Once they aligned the pulleys and replaced the belt the SC was fine. PS - It was shockingly slow without the SC working...like 7-8 second 0-60 slow.
Old Aug 5, 2021 | 11:36 AM
clubairth1's Avatar
Well I am confused again as the pulleys are NOT adjustable?
They only bolt on in one position and the only thing that does move is the spring loaded tensioner.
Old Aug 5, 2021 | 04:37 PM
Flerkin's Avatar
I'm not a mechanic so just going by what I was told, the reason the belt came off according to them (Jaguar dealership service) was that the pulleys where miss-aligned when the engine was replaced and as a result the belt came off.
Dave Redline
Mar 27, 2021 09:21 PM
glenn b
Jan 29, 2021 08:58 AM
David_h
May 11, 2014 09:29 PM
Bacardi 151
Sep 22, 2011 06:34 PM
