XF 2017 , 3 L diesel oxygen sensor
Old Sep 13, 2024 | 04:33 AM
PaulBDS's Avatar
Default XF 2017 , 3 L diesel oxygen sensor
I currently have my car up on ramps to change the oxygen sensor , I am sure there must be a trick to teaching the almost impossible inaccessible nut , the final piece to removing the existing sensor, I have tried everything I can think of. The bolt is long and preventing me from getting the socket on , I have a 50mm socket but it’s too short , a 100mm , too long. Can anyone advise ?
Old Sep 14, 2024 | 10:47 AM
clubairth1's Avatar
Community Influencer
Why not use an O2 socket?
Easy to find at any parts store too.
Two kinds available. I have and recommend both styles to give you options. There is NEVER enough room!
Or this kind.
Sometimes a plain old 7/8" box end wrench will work too.
Old Sep 15, 2024 | 10:02 AM
PaulBDS's Avatar
Or this kind.
yes need to get that second one , any hints on how to undo the clip ?
Old Sep 15, 2024 | 10:05 AM
PaulBDS's Avatar
Default Hi , yes I’ll get th second one in the morning ,
Any hints on how to undo the plug on the end of the oxygen sensor lead ?!
Old Sep 16, 2024 | 08:44 AM
clubairth1's Avatar
Not really? It's just a push tab and then pull apart the connection but again as you found it's just not that easy! I never have enough room to get both my hands on those connectors. I have resorted to using a screw driver to pin or hold the O2 connector against the car body so it does not move and use bent needle nose pliers to compress the tab. Since it's all plastic watch how rough you get with it.
It does help if you have the new O2 sensor as you can sorta practice on that push tab on the bench. Instead of on your back with no room and little light under the car!
Old Sep 16, 2024 | 08:53 AM
PaulBDS's Avatar
Default Ahhhhhh
[QUOTE=clubairth1;2786119]Not really? It's just a push tab and then pull apart the connection but again as you found it's just not that easy! I never have enough room to get both my hands on those connectors. I have resorted to using a screw driver to pin or hold the O2 connector against the car body so it does not move and use bent needle nose pliers to compress the tab. Since it's all plastic watch how rough you get with it.
Yes I have just ordered the new one and thought at least I can have a look at that in good light rather than fumbling in the dark !
Thanks for your advice.
Old Oct 12, 2024 | 04:07 AM
PaulBDS's Avatar
I beat it finally, new parts fitted and fault code cancelled . Thank you for the help.
Old Oct 15, 2024 | 09:30 AM
PaulBDS's Avatar
Now I have P0670-13 Fault code , glow plug module control unit. I am told it is under the right air flow box, I've removed that but I see no glow plug unit!
Gelmundo
XE ( X760 )
May 25, 2024 11:19 AM
Jakejag
Oct 25, 2021 01:34 PM
Art
Diesel variants - All models
Jun 14, 2021 06:04 PM
Roger95
XJ40 ( XJ81 )
Feb 15, 2018 09:17 AM
